Bronco II Ford Bronco II
89 bronco problems
Old Aug 14, 2003 | 12:46 PM
thewupk's Avatar
thewupk
89 bronco problems
I have a 1989 bronco ii and it has problems running.
Usually it will start right up. But after I drive around for 5 minutes or so and I let up off the gas. It just suddenly dies. And I was at McDonalds the other night and I had to keep my foot on the gas at the drive through so it wouldn't die. But after waiting for 10 minutes it died anyways. And then I have to wait roughly an hour before it will start up again after that.
I just got the battery replaced today because it was very old thinking that might be the problem. Well it's still doing the same thing as before.
Any idea what the problem could be?
Thanks
Old Aug 14, 2003 | 01:15 PM
mrshorty's Avatar
mrshorty
89 bronco problems
idle control valve could be dirty or malfunctioning.
TPS not responding properly
TFI module could be a possibility
Could be lots of things.
Try pulling trouble codes from the computer and see if there is any information there.
Check fuel pressure, especially when it won't start.
Check for spark when it won't start.
Old Aug 14, 2003 | 06:14 PM
_rich_'s Avatar
_rich_
89 bronco problems
And it can't hurt to pull the IAC (idle air control) off the side of the manifold and clean it up.
Old Aug 15, 2003 | 01:39 PM
thewupk's Avatar
thewupk
89 bronco problems
When it begins to die on me it sounds like that it's running out of gas. But I know that's not the case.
When it comes to cars I'm as ignorant on the matter as anyone can be. Where would I go to find out how to do some of the stuff yall have suggested?
Old Aug 15, 2003 | 02:46 PM
mrshorty's Avatar
mrshorty
89 bronco problems
A Chilton's or Haynes manual would be a good start.
The vehicle repair guides at www.autozone.com are the equivalent of Chilton's, but I find the electronic version more difficult to use. I can find something faster in the hardcopy version.
You could find some manuals and other information at the library.
Any family members/friends/neighbors that dabble in auto repair?
And, of course, FTE. Let us know how else we can help, and we'll do what we can.
86F250_7.5_4x4
May 30, 2016 09:35 PM
Nickster225
Jul 28, 2014 07:57 AM
richfoub
Nov 10, 2013 08:03 PM
Trialsguy
Bronco II
22
Nov 10, 2004 10:26 AM
beno
Bronco II
Aug 13, 2003 07:24 AM
