94 Explorer - Acecelaration stall
Old Aug 14, 2003 | 12:45 PM
coqui's Avatar
coqui
Unhappy 94 Explorer - Acecelaration stall
Hi guys, I installed a conical filter (k&N style), new spark plugs (0.054) and wires also cleaned the MAF sensor. Now I'm noticing that the acceleration stall, and when I don't apply gas pedal the engine start shaking. When I press the gas pedal it runs good.
The engine light does not comes on. What I need to do or check next?
Just whent to a service station and they want to charge $60 just to hook up the computer.
Need help please!!!!!
Old Aug 14, 2003 | 02:38 PM
CobraXP's Avatar
CobraXP
Welcome to FTE Coqui
I would put a new fuel filter on it. Could be the filter is clogged, and as long as you are giving it gas, it has enough force to pull fuel through, but when you let off, the pressure goes back down...
Old Aug 14, 2003 | 04:53 PM
mrshorty's Avatar
mrshorty
I would also check the IAC valve. See if it needs cleaning.
Old Aug 16, 2003 | 02:19 AM
ThePheonixx2's Avatar
ThePheonixx2
if the engine is loping badly you might check for a vaccum leak??? most likely if there is one it is at that rats nest of vac lines near the intake (drivers side) near the firewall
