messed this up posted new
i need help identifing this motor it has the mirror 105 and its a D3TE block
casting / part #s
intake manifold C5AE-9425C
exhaust manifold C3SE9431B & 5C8
bell housing C1SP-7976-A
casting by 1st spark plug is 43
casting in between 2nd & 3rd
Received 3,108 Likes
on
on
on
to measure stroke pull a spark plug and piece of stiff wire int he plug hole. slowly turn the engine over until it reaches bottom and mark the wire. then slowly turn engine over until the piston tops out and mark the wire again. measure the difference. if you get 3.78 inches, it is a 390
on
on
Two threads going. That engine is a mish-mash of parts, but could still be a 410. Just not an OEM 410, but rather one built in the field by a prior owner. More graphic detail here:
https://www.ford-trucks.com/forums/1...hat-is-it.html
abcamacho
07-14-2019 12:45 AM
1browski
06-30-2019 03:12 PM
Build it right the t
03-29-2018 08:42 AM
treverd
04-17-2016 01:01 AM
