Did power steering conversion and doesn't work!
Old Apr 30, 2016 | 11:18 PM
straight-shot's Avatar
straight-shot
I did a power steering conversion on my 70 f250 4wd and am having problems. I used the power steering pump and steering box from a 1970 2wd. Put new seals and gaskets in pump and box.
If I turn the wheel very slowly the power steering works but if I try to turn fast like turning into a parking lot, no power steering. It's like the pump can't keep up or something.
What could be the problem?
Thanks in advance!
Old May 1, 2016 | 01:43 AM
GaryKip's Avatar
GaryKip
Did you prime the new pump before you started the engine? Then did you work the air out by moving the wheels lock to lock a few times?
Old May 1, 2016 | 04:16 AM
jowilker's Avatar
jowilker
X2 with Gary, No Cost, raise the front wheels and turn the wheel coast to coast about 20 times. This can get air out.
John
Old May 1, 2016 | 11:30 AM
straight-shot
Thanks for the replies!
Yes, I turned the wheel back and forth many times before starting. I put new o rings and seals in both before mounting but had never rebuilt one before so I can't guarantee my work.
Old May 1, 2016 | 11:51 AM
ultraranger's Avatar
ultraranger
Whenever I add power steering, replace a PS pump or have to open up a PS system to replace hoses or parts, afterwards, I prime the system with a variable speed drill motor to purge the air out of it --BEFORE I ever put the belt on the pump and fire the engine up.
The idle speed of an engine is way faster on the pump than a drill motor being turned at low RPMs. This is when a pump gets burned up or damaged from air pockets in the system that keeps the pump from being completely submerged in fluid, when it's being spun from the engine. Whining from a hydraulic system is an indication of cavitation (air trapped in the system). This is damaging to the pump.
Variable speed drill motor and a 3/8" hex bit engaged into the drive on the pump shaft to purge the air from the system, prior to putting the belt on and firing up the engine.
Robbrown20
Aug 9, 2018 07:57 PM
J C Hope
Apr 14, 2016 05:43 AM
hotweekend
Jan 13, 2011 04:39 PM
icovy
Dec 12, 2006 06:03 AM
aerocolorado
Aerostar
Apr 22, 2005 01:53 PM
