turbo pipe issue
Old Apr 30, 2016 | 02:22 PM
lockhartdagreat's Avatar
lockhartdagreat
turbo pipe issue
Hello everyone. On my 11 ford f 250 SD 6.7, I got in it yesterday and I hear a loud pop. Open the hood and the black pipe that runs from the turbo under the upper radiator hose was sticking straight up. It blew off what I consider to be an intake. What causes this. This is my first diesel so sorry for not knowing actual part names. Any help
Old Apr 30, 2016 | 06:06 PM
UGA33's Avatar
UGA33
Crappy design. There are aftermarket options to remedy this issue. Here is a kit for guys wanting to stay with stock tuning and hardware:
H&S Motorsports 11-15 Ford 6.7L Intercooler Pipe Upgrade Kit (OEM Replacement)
Old Apr 30, 2016 | 09:57 PM
AzBlueOval's Avatar
AzBlueOval
I just installed my intercooler pipe from H&S yesterday, as a preventive measure. Ordered from No Limit, they were the cheapest I could find.
Old May 1, 2016 | 07:05 AM
senix's Avatar
senix
How hard was the install?
Old May 1, 2016 | 08:26 AM
UGA33's Avatar
UGA33
Install is pretty straightforward Scott. The 90* boot is a tight fit which can be a pain sometimes, but install is pretty easy.
Old May 1, 2016 | 07:37 PM
AzBlueOval's Avatar
AzBlueOval
Yep, pretty easy. Only need a couple different sized sockets and a couple long extensions will help. The most complicated (or nerve racking) part is cutting off the stock band from the factory boot you have to reuse. I just took it slow with the dremel and the tension from the band eventually popped itself apart.
bio-d
Aug 6, 2013 03:29 PM
old-rodder
Jun 11, 2013 05:11 PM
FLATTIE
15
Feb 14, 2011 01:36 PM
markus arailius
Feb 24, 2008 01:43 AM
