Sponsored by: Real Truck
Chasing Gremlins
Old Apr 30, 2016 | 01:09 PM
Willygee's Avatar
Willygee
Unhappy Chasing Gremlins
Morning,
I have a 2001 F 250 extended cab Lariat 7.3 diesel. I came out one morning and had no power windows, interior lighting, cruise control or power mirrors.
I have removed the dome light, disconnected all switches in both doors, window motors and mirrors.
I have replaced the G.E.M but have not put power back to the system since disconnecting to remove the fuse box and old G.E.M.
I have checked with an Ohm meter and found a direct short in the dome light connection at the roof, the right/passenger side of fuse #4, green power wire in left side power mirror and black/white wire on left side power window control. Any suggestion or information on where the best place to find where these wires all run together or best way to chase this down would be greatly appreciated.
I am new to this forum so please let me know if any further information would be helpful.
Old May 1, 2016 | 08:22 PM
Willygee's Avatar
Willygee
Chasing Gremlins
Thanks for the input.
I just pulled the light and dome light switch along with all courtesy lights, dome light fixture,cargo/brake light fixture, glove box bulb and fuse box/G.E.M.
Still anything associated with the Light Green/Yellow wire and the Light Blue/Red wire off of the dome light control are going to ground.
Any ideas?
Old May 1, 2016 | 08:48 PM
Shepherd2's Avatar
Shepherd2
The LB/RD wire is power for instrument illumination and the LG/OG wire goes to the courtesy lamps and is grounded when the interior light switch is on. The cruise and power mirrors are on totally separate circuits so that is weird. The power windows and interior lights both get power from the accessory delay relay in the central junction box. A lot of people have mentioned water leaks in that area can cause all sorts of strange problems.
Old May 3, 2016 | 06:42 PM
Willygee's Avatar
Willygee
Chasing Gremlins
03 May 2016 04:40
Afternoon;
Latest Update:
- Dash and instrument cluster along with all dash controls and heater control is turned off.
- Central Junction Box C242a is showing ground on pins #10 & 30
- Central Junction Box C242b is showing ground on pins #7, 8, 15, 16, 25, 31 & 33.
- Also still showing ground Lt- Grn/Ylw on drivers side door and Lt-Blu/Rd on dimmer/dome light control
I have also attached photos of the 3 plugs off the back of the instrument cluster;
- #1 shows no grounds
- #2 shows grounds on pins #7 &11 from left to right
- #3 shows grounds on pins #1, 3, 11 &12 from left to right
Old May 3, 2016 | 06:48 PM
Willygee's Avatar
Willygee
Old May 10, 2016 | 12:20 PM
Willygee's Avatar
Willygee
Winner Winner Chicken Fing Dinner! I finally found it. It was the wire they used to pick up power for the canopy when it was installed. It had an inline 10 amp fuse that did not blow and was piggy backed into the light green/yellow wire running to the under hood trouble light tucked into the factory wire protector and wrapped in electrical tape. When they put it in they ran it under the truck and did not secure it at all so I am amazed it lasted this long.
Thank You for you help!.
Old May 10, 2016 | 12:26 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Glad you found it!
I removed a post above with two large copy-and-pasted images and a bunch of other stuff. Apologies to the guy who posted it, but it wasn't relevant to this thread anyway.
Jackson95
25
Jun 24, 2018 07:56 PM
BainbridgeBrewer
Dec 31, 2016 08:38 PM
79Ford-4x4
Mar 15, 2016 08:23 AM
KidWithTheLoudFord
Jan 23, 2016 02:20 AM
truckerted
15
Aug 11, 2015 11:18 AM
