cab dome lifgt
There is no ground connection to the dome light switches or the headlight switches. These switches switch power, not ground.
1) Make sure you have 12 volts on both sides of the courtesy lamp fuse. This circuit is hot at all times, so it doesn't make a difference what position the key is in. If you have power on only one side, replace the fuse. If you don't have power on either side, then there is other work to do first.
2) Pull the dome light switches out and remove them. Make sure the terminal for the GREEN with YELLOW stripe wire in the connector has power.
3) Check the dome light switches for continuity. With the plunger all the way out (switch CLOSED), the switch should be shorted. With the plunger pushed all the way in (switch OPEN), the switch should be open. If not, replace the switch.
4) With power to the switch proven to be good, and the switches proven to be good, the dome light should light up. If the dome light does not light up, remove the cover and check for power at the dome light (not the side that's permanently grounded to sheetmetal) with the door OPEN. If you have power here, yet the bulb does not light up, replace the bulb.
This will prove out the door-side; if you get to the point that the doors turn the light on but the headlight switch will not, then we can cross that bridge.
ND
yes I know it was the cargo light...
but it gave him more info than he had in the 1st place, and the wire routing is close to the same.And your pics explains it even more, so thanks for another pic.
Quick question though... Are there any other years of these trucks that have the same/as near as damn it cargo lights installed? I'm trying to find one to replace the one on the rear of my truck (cracked lense, dodgy gasket, bleached bezel etc, etc) but the only ones I've found so far have been online and they seem to want a kidney for them. There are a couple of 80's and 90's trucks parting out on CL, so would I be able to use a light from one of those? Just testing the water before I jump on buying one!
Thanks again Rich for showing me the way!
I've blown the courtesy light fuse twice now and I'm struggling to understand why. So here's what's happened/I've found so far...
1/ Found the connector to the cargo light disconnected. Reconnected it, no light but blown fuse with the switch inside the cab in the "ON" position.
2/ Disconnected cargo light and replaced fuse. Tried again with a test lamp in the connector, getting supply to the cargo light connector...
3/ Tested continuity of the supply wire and found to be good.
4/ Tested continuity between supply to cargo light and chassis/ground... continuity found!?!?!?
5/ Checked switch and found continuity between ALL connections when in the "ON" position. When in the "OFF" position, only continuity between green/yellow connection and black/blue (two wires) connection.
Forgive me if I'm wrong, but this switch is supposed to switch the supply to the cargo light and not the ground right? How come I'm getting continuity to ground when the switch is in the "ON" position then? This doesn't make much sense to me... I would say that there is a ground in the light holder, but then when testing between the cab side of the light supply and the chassis, I wouldn't get anything right?
Just as a note, this light hasn't worked since I bought the truck and the only other thing I've done that could have affected this is changed the door jamb switch on the passenger door (thinking green/yellow wire that runs to door switches).
Someone please help!!!
I was meaning that I was getting continuity to ground when testing on the supply side to the light, as in the wire that runs from the switch to the light with the light disconnected. But would the multimeter act as a component in that regard and give the continuity? I don't think so, but now I'm not sure.
From what I've read and can figure out, I should only have 12V at that connection and shouldn't have circuit continuity to ground on the cab? The only other thing I've noticed is that I don't blow the fuse when the cargo light is disconnected, regardless of the switch position, and do when it's connected again. Based on this, I can only guess that the actual light fitting is shorted out and that's what's causing the issues. It would make sense as the gasket is knackered and has been letting water in behind the light fitting for some time now!
I'm going to replace the light fitting and see if the situation is resolved with that, but if not I'm going to have to dig further!
So, it's not hijacking if you are fixed up, plus don't really want to start a new thread on the same topic
I went to the JY and grabbed a few door jabs as mine were rusted "door closed" position. My dome light itself works perfectly, with the **** to turn it on. Each truck I grabbed the jabs from - the drivers side has 3 wires on the jab and the passenger has 2 wires. I'm sure there is a reason. However, I got these JY ones cleaned up and wires stripped ready to go. I remove my drivers side and it only has 2 wires, black and green - no red like my junkyard finds. Thinking my JY finds were from like 80s ford trucks. So, Am I still good with just the 2 wires on both sides you think?
this is my drivers side jab.
I had to replace a dome light assembly once, it looked fine but was broken, only replaced the part that was screwed to the truck and everything worked again
cab light assembly has a plug to unplug to replace cab light assembly, can also test at the point for power to check the wiring is good between the switch and the cab light, and then retest with assembly in place
cargo light wiring plugs into dome light circuit wiring on driver side, need to pull cluster out to get at dome/cargo wiring light circuit plugin, you can test within that plug to make sure you getting power to that point and then if getting power you can test at the door jamb switches and cab light itself
cargo light is a metal piece on 73-77 cargo lights, apparently it is a different design for 78-79s
77&79F250's diagram shows the 73/77 style. I am not sure of the 78-79 construction but like you say the seal is old and water has been getting in then I would check on that
the headliner trim is held in with metal screws through a metal roof, if one of those were to puncture the dome/cargo wires that run along the driver side then that could be a probable cause of the shorting
also the cargo light has a ground wire with ring terminal to check it is grounding properly too
I added a cargo light to a truck and hit the switch and had no light, the light socket was slightly corroded and the bulb was burned out, I sanded socket and replaced bulb and it worked
make sure of the position you left the headlight switch in, on to the left to manually turn on cab light or in natural position for when driving
ALSO: the under dash lights (if equipped) one illuminating each footwell, also plug into the doorjamb circuit, also in the same place that the cargo light plugs into in behind the cluster to the left, near the headlight switch
ALSO: the cig lighter uses a green/yellow constant power wire as well (I'm not sure if it is the same circuit, I do believe it is the same as dome light)
Whew! I think that covers it...
Have you solved it yet?
The extra wire on the later-model ones is probably for the door-open/key-on buzzer. You're fine just using two of the wires, as long as you tape off the other one so it's safe (it'll be hot when the door's open). If your door alignment doesn't match up with the used switches, you can buy new ones - they're auto-adjusting the first time you close the door.
