Aerostar Ford Aerostar
Brown power steering fluid
Old Feb 4, 2007 | 11:04 PM
  #46
xlt4wd90's Avatar
xlt4wd90
Just an additional note about that cowl drain hose: It tends to get clogged with crud collected in the cowl. When it does get clogged, the water will back up and find other less desirable routes to get out. So it's a good idea to regularly clear out the crud.
The very end of that drain hose is soft rubber, and you can grab it with your hand to crush whatever is caught inside and let it fall out. Running a little water into the cowl can help this process.
Old Feb 8, 2007 | 06:06 PM
  #47
Aeroman59's Avatar
Aeroman59
Power steering (goop) Fluid
I also have brown (mollasses based) PS Fluid. I like the trick with the drain **** in the return line!
Mines been in there for 250,000 kms & it is not over noisy but it looks pretty disgusting. I've promised to change it when the temp gets above 0* c ,which might not be for a few months yet!!!! I think I'll go with the synthetic stuff; it might outlast the vehicle though.
My only problem at the moment is use of AF coolant at about 250cc/ week or 300 kms, but I might splash out for another radiator when the spring comes.
ATB Aeroman.
Old Feb 9, 2007 | 12:38 AM
  #48
xlt4wd90's Avatar
xlt4wd90
Aeroman,
You have a coolant leak. I recently described the intake manifold leak on one of my vans. It looked daunting initially, but I managed to do it in a couple of days. But I didn't have to deal with sub-zero temps this time. (I did something like this on a 2.8 liter v6 in the middle of winter in Detroit many years ago, and I still have miserable memories.)
The only things worse would have been 1. Freeze plug leak or 2. Head gasket leak.
Old Apr 4, 2007 | 06:07 PM
  #49
Aeroman59's Avatar
Aeroman59
P.S. pump whine
Originally Posted by rob1994AerostarAWD
Hi Copper,
The pump still whines with the Amsoil Synthetic Mercon ATF. I cannot hear it whine while driving unless I slow down and turn sharp. I can hear it whine clearly while turning in park in the garage. But ... I just got brand new front tires which is a factor in the level of friction while steering. I am not sure if the power steering pump is quieter than before with the Amsoil synthetic mercon ATF in there. I never paid close attention to steering systems until this incident with the brown power steering fluid. I am so glad that I noticed it. If anything unusual happens in the coming months/years I will update this thread.
Mine has always whined, even since almost new. I think it's just the design. It makes no more noise after 265,000Kms than it did at 75,000 kms,even with the brand new Mercon in it!
Like yours I can really only hear it at low revs & sharp turns, which is also when the pump is running at a slower speed. I dont worry about it....... my steering feels fine & it has no leaks (not for about 200,000 kms anyways).
Old Apr 4, 2007 | 09:31 PM
  #50
xlt4wd90's Avatar
xlt4wd90
For a short while, I had type-F ATF in my PS pump, and the whining was reduced. Once I read the instructions that said the pump needed Mercon, I switched back, and the whining got louder.
Old Apr 4, 2007 | 09:51 PM
  #51
rob1994AerostarAWD's Avatar
rob1994AerostarAWD
Mine is still running great with Amsoil Synthetic ATF. I never hear it, because I have to turn sharp and slow to hear it, and I never do that.
Clover_SD
Dec 4, 2016 05:15 PM
Anthony Bauwens
Nov 14, 2016 12:10 PM
EMC V10 X
May 13, 2011 07:56 PM
Myfreeford
Feb 28, 2011 10:06 PM
moenko
1983 - 2012 Ranger & B-Series
Sep 4, 2003 01:51 AM
