Tree Line Find Update
Old May 3, 2016 | 12:41 PM
cowmilker08's Avatar
cowmilker08
P0603 means you disconnected the batteries at some point.
Old May 4, 2016 | 08:49 AM
rollingflat's Avatar
rollingflat
Thanks for the conformation on the battery code. Is there any thing else that throws the P1280 code, before I spend the $ on the ICP? Around me its $180 plus $80 for the pig tail.
What about the sensor in the back of the hpop reservoir? It is tied in to the same harness as the ICP?
Old May 4, 2016 | 09:07 AM
Hussler's Avatar
Hussler
<table style="font-size:14" border="1" cellpadding="1" cellspacing="0" width="100%"><tbody><tr bgcolor="70D6AD"><td align="center" valign="top">1280</td> <td align="center" valign="top">ICP</td> <td align="left" valign="top">ICP circuit out of range low</td> <td align="left" valign="top">Uses inferred ICP strategy</td> <td align="left" valign="top">Open/grounded circuit, biased sensor, PCM</td></tr></tbody></table>
Could be the sensor, could be the pigtail. Stick a safety pin on the wires, 1 wire is ground, 1 wire is +5 volts and the last wire is signal to PCM. Measure each with a volt meter if you have one. Above code means PCM is not detecting any signal from ICP. At idle it should be about 1.2 volts, IIRC.
Sensor on back of HPOP reservoir is engine oil temp.
Old May 4, 2016 | 10:20 AM
oldbird1965's Avatar
oldbird1965
Check Riffraff, they are about $140.
Old May 4, 2016 | 10:33 PM
rollingflat
Ok replaced ICP sensor it was bad. Cleared code and it runs like a beast again. Installed aeroforce scangauge in empty spot in dash next to idiot lites, looks great! Now I will get the rest of accessories to monitor bost, egt, and trans. temp. Thank you to all that gave help in diagnosing the problem and help with engine code deciphering!
Old May 5, 2016 | 07:44 AM
Jarrett Campbell's Avatar
Jarrett Campbell
Glad you got her running! Always a great feeling
Old May 5, 2016 | 08:38 AM
Hussler's Avatar
Hussler
Scan gauge is already setup to monitor boost and EOT. You really only need EGT gauge. Got this one from Riffraff ...
90150xlt
Jan 26, 2018 08:48 AM
SRBF150
Aug 9, 2016 05:02 PM
thewellman
Jan 31, 2012 06:16 AM
officer131
30
Nov 23, 2009 08:10 AM
Pete in Maine
Jul 10, 2008 12:14 PM
