programmed or copied key ?
Old Apr 27, 2016 | 04:51 PM
Pele's Avatar
Pele
Originally Posted by pirate4x4_camo
why will I care if I ever have to replace the PCM or PATS ?
I am guessing that regardless if I have a cloned or unique key that replacing the pcm or pats is going to require the new modules to be programmed ?
PATS module can't have less than 2 keys because of the problem I talked about above.
So the Engine Control Unit and the PATS module are married together. This is so that thieves can't carry around an extra PATS module with them.
If your existing PATS module dies, you haul the Ex to the dealer. They replace the PATS module and remarry it to the ECU. They'll need a pair of keys to set it up properly.
If you're already paying for a service, what's another $50 on a new key.
Old Apr 27, 2016 | 06:16 PM
Stewart_H's Avatar
Stewart_H
Ever since those cloning machines hit the hardware/home improvement stores, the only "problems" I've really seen affect users who post on the forum is the realization that a unique key and a cloned key will not work together to great a third programmed key.
Stewart
Old Apr 27, 2016 | 06:20 PM
Psyclopse's Avatar
Psyclopse
Originally Posted by projectSHO89
Stuff happens... stuff breaks and has to be replaced.
If either the PCM or PATS modules ever has to be replaced, you'd been given a heads up.....
Take it from me- he's right.
Old Apr 27, 2016 | 06:33 PM
pirate4x4_camo's Avatar
pirate4x4_camo
FTE Remembers
I am well aware that stuff breaks and in anticipation of someday needed to replace my PCM or PATS , I am asking for clarification as to why I will care or what difference using a clone key is going to make when I need to replace those parts.
Old Apr 27, 2016 | 06:37 PM
pirate4x4_camo
FTE Remembers
I assume he is, that is why I am asking what difference it makes if I use a copied key. "
since you are or were in the process of swapping you pcm or pats last time I read your thread. what difference did having a copied vs clone key make in your swap ?
I recall your challenge was that you were a considerable distance from the nearest dealer and taking it to them for programimg was expensive and a hassle ?
Old Apr 27, 2016 | 06:43 PM
pirate4x4_camo
FTE Remembers
Stewart
that was more or less my assumption but know it sounds like there may be some other major issue lurking that is going to present itself when or if I ever have to install a new pcm module
Old Apr 27, 2016 | 07:49 PM
05MilMachine's Avatar
05MilMachine
My biggest problem with the clone keys was that they had a battery when they first appeared. It held the code in the key and when that battery dies the key would no longer work. I am told they have keys without batteries that can be cloned these days but most stores won't touch someone else's keys. As long as the clone key doesn't die or go corrupt you should be good to go.
Old Apr 27, 2016 | 08:24 PM
Stewart_H's Avatar
Stewart_H
One could always make several clones and just put the remaining master unique key in a safe place.
Stewart
Old Apr 27, 2016 | 09:04 PM
pirate4x4_camo
FTE Remembers
Stewart
not knowing if additional copies could be made from a copy that is exactly what I did. better safe then sorry. but now it seems there is some other "copy key" gremlin lurking in the shadows.
planning on owning a obsolete vehicle for many decades takes a little bit of for though but what scares me the most is exactly this sort of computer glitch. it might be 30 years from now and I'll be old and senile before it comes up but damn it if I will not have a contingency plan.
Old Apr 28, 2016 | 06:08 AM
Psyclopse's Avatar
Psyclopse
The difference is when I drag my beast to the dealer with it's new PCM and new PATS, they will not (can not?) program it with just my one original key. I could bring in one unique PATS key and a dozen clones and they won't touch it without a second unique key.
My fear in your situation would be taking a trip somewhere far away from home and having the PCM and/or PATS system screw up while running on only clone keys. Your emergency dealer stop just got more expensive, as they would make you purchase, cut and program 2 new unique keys, in addition to the parts and labor bill.
Old Apr 28, 2016 | 07:55 AM
henryr's Avatar
henryr
ahh, that is why i asked about how they were powered. i have three cuts keys from previous owner. non work. all some "S" name printed in them. sertec or something
Old Apr 28, 2016 | 08:04 AM
Pele's Avatar
Pele
Stratec. That's the brand name that manufactures the keys and locks for Ford and many other car makers.
Old Apr 28, 2016 | 08:51 AM
  #28
05MilMachine
Stratec is the ones to have. They may just need programmed to the truck. Another time where I recommend giving forscan a try. It was able to add another unique Stratec key to a Mountaineer I had with only one key.
Old Apr 28, 2016 | 11:55 AM
  #29
Watcher58's Avatar
Watcher58
Don't worry, if you hit the senile part, it will start for you wether you have a key or not!
Old Apr 28, 2016 | 01:01 PM
  #30
hstechteacher's Avatar
hstechteacher
So this discussion has gotten me to realize that I am fool for not having extra keys made asi only have one!! So looking on eBay there are hundreds of sellers!!
How does this one look? http://m.ebay.com/itm/2-New-Black-Keyless-Remote-Alarm-Fobs-2-Uncut-Ignition-Transponder-Chip-Keys-/381042562191?nav=SEARCH
And yes I am going to try for home dumpo approach yielding me only "clones"
Just can't see spending the $125 that ford wants to make a key
