7.3l blew out rear end, 6.0 suspension and gearing help.
Ok guys well the day has finally come. 2002 f250 4x4 long bed crew cab. I bought a 2006 6.0 suspension back in September and had an idea of doing the swap this summer. Well heading out to lufkin Texas my rear end blew out and sent my driveshaft flying at an rv (no damage to the rv) sheared the pinion right off the rear end. At any rate I'm now forced to do this swap because I don't have time to find another 7.3 rear end and I already have the front and rear end off this 6.0 so I'm gonna go for it. To begin, I'm gonna be re-gearing the differentials the stock is 3.73 but I'm running 35x 12.50 x 20s so I'm thinking about 4.10s (all tho I haven't been able to find 4.10s just 4.11s and 4.56s.) I'm doing both front and rear end (obviously) so which brand or where can I find them? I do a lot of highway driving so I would rather have the 4.10s since 4.56s seem to be an overkill for me and 4.10s seem to be a good number. On top of that I will be going to old post to see what it all takes to do the swap i understand the rear end is easy and is just a bolt ok set up to were the front end is in need of some custom work. So here's the list of what I'm gonna do to the suspension.
Things to be done,
All new ball joints, new bearings, Monroe gas shocks or billstein(think that's what that brand is called) leveling kit (since mine already has the 2inch leaf springs) anything that looks like it needs replacing tie rods etc and also getting 238/80 injectors from rosewood, 6.0 steering box and brake booster. I guess the only thing that I'm not too sure about is how to secure the spring buckets to the fram since they were riveted to the 6.0 frame. Also trying to find stock or after marker brackets for the back end of the front suspension( they guy I got the suspension from didn't have them) and I don't really know what to do about that issue. Anything about the gearing and fasteners on this build would be very appreciated. Especially gearing since I have no idea where to even look to get those, thanks guys hope to get this build done asap!
Things to be done,
if you want the 4.10's but can't find them just grab a set of 4.11's, if its a 4x4 make sure you get matching sets, front and rear, the difference between 4.10 and 4.11 is very minimal, maybe a 500 rpm difference to 1k difference at most (i would think it will be closer to 500RPM difference) so either way you should still be good...
