top of door rubbers
Old 04-25-2016, 04:39 PM
mjr46's Avatar
mjr46
mjr46 is offline
top of door rubbers
So I got a complete weatherstrip kit from thebrocograveyard.com and it came with two , 26030a top of door rubber seals........I can't remember where they start on the door and end, any pics or installs would be helpful?...............I can't remember if mine had them or not but they say for 73-79 f150's. my truck is a 77 f150 4x4
Old 04-25-2016, 07:11 PM
tndallas's Avatar
tndallas
tndallas is offline
top of door rubbers
Mine ends on the floor under the metal trim. the trim hides it and protects the ends from coming up.
If you install the window felt look for little curfs that fit at the top back of the window track. those cuts help it transition around that sharp turn of the window.
Ask me how I know about them.
Old 04-25-2016, 08:39 PM
mjr46's Avatar
mjr46
mjr46 is offline
that's not the piece I'm talking about, I think you are referring to the cab weatherstripping that goes under the metal door sill trim.......I'm referring to the top of door rubbers that go on top if the door.......anyone have a pic and know what I'm talking about?
Old 04-25-2016, 10:30 PM
hail destroyer's Avatar
hail destroyer
hail destroyer is offline
Im wondering this too. Ive never seen them on a 73-79 ever, yet there is a P/N for them. When I try to explain the issue everyone thinks Im talking about door seals. Nope.
I'd love to see a pic of the top of door rubber seals installed.
Old 04-26-2016, 07:22 AM
mjr46's Avatar
mjr46
mjr46 is offline
glad I'm not the only one with the question and understanding of the issue Reminds me of Ferris Buellers day off.........Bueller, Bueller.....anyone, anyone?? Would be cool if anyone has pics and can elaborate on the issue?
Old 04-26-2016, 08:10 AM
gumshoe's Avatar
gumshoe
gumshoe is offline
my 79 came with top of door rubbers, they were to cut down wind noise they ran from over the top and down the rear of door. carpenter sells these rubbers, you might look and see exactly how they fit. I'm going to put a set on my 74.
Old 04-26-2016, 08:22 AM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Moderator & parts seller
Received 3,290 Likes on 2,446 Posts
I sort of remember seeing them on some trucks pretty much evened up with a equal amount coming down a little on both sides? Not sure if this is right?
Old 04-26-2016, 08:27 AM
hivoltj's Avatar
hivoltj
hivoltj is offline
I know what you are talking about tho I don't think any of my trucks had them. I think they were added after the fact. A TSB maybe?
Old 04-26-2016, 09:31 AM
mjr46's Avatar
mjr46
mjr46 is offline
YES!!!!!!!!!!! that is what I am talking about......do you have a pic of the other jam side???
Old 04-26-2016, 09:33 AM
mjr46's Avatar
mjr46
mjr46 is offline
I have a set but before I goober them up I want to make sure I put them on right and in the correct place as there are no installation instructions
Old 04-26-2016, 10:34 AM
orangeford's Avatar
orangeford
orangeford is offline
I am pretty certain they came on 78s and 79s. Which would explain why you don't usually see them on the older models. I have seen places like LMC and broncograveyard specify those years for those seals. They would certainly fit earlier years to 73.
Old 04-26-2016, 12:04 PM
77&79F250's Avatar
77&79F250
Can you say G-O-G-G-L-E ? That is what I did to get that pic. lol
No top seal, but another vid.
Old 04-26-2016, 12:16 PM
mjr46's Avatar
mjr46
mjr46 is offline
North Carolina F-150 Window Channel Replacement - YouTube
No top seal, but another vid. 1978 F-150 Build Part 14 Updates & Window Channel Kit - YouTube
I did google for 2 hrs, but apparently I looked at all the wrong threads........but thank you for being better at google than me! Also, none of the vids there really show me any of what I want to know, just the pic and it doesn't look like it's installed properly/down both sides like I've seen.
Old 04-26-2016, 12:37 PM
77&79F250's Avatar
77&79F250
Yes like I said I remember only seeing that door top seal hanging down the curve edges only a few inches. I am going to ck both side of my parts trucks/Bronco's for you.
If still installed I will get pics of BOTH sides.
Old 04-26-2016, 01:03 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
D8TZ-1020518-A .. Weather Strip-Front Door Upper / Reproduced
1978/79 F100/350 & Bronco.
No parts catalog listing for these weather strips for 1973/77.
Quick Reply: top of door rubbers
