Is anyone near Birmingham? Interested to have someone put eyes on these wheels. There are two HD wheels and two whatever, seller has center caps but no lugnuts. Price is for all four wheels shown in ad.
They look good, yes some trimming will be required on your fiberglass header panel, or you could get an '05 header panel for a little over a hundred and not have to trim any.
You will have to cut the header panel and need adapters for the bulbs which Riffraff Diesel sells. I am guessing those are a aftermarket set based on pricing.
If you decide to change header panels, might as well upgrade to the 05+ front end.
From what I have ascertained...trimming the 99-04 header panel eliminates so much material that you are better off getting the newer header panel.
Thanks for the heads up on the adapters. I wasn't aware of that. The ad says that they are "stock", which I thought meant they are oem. I will have to get in touch with him and find out.
Anyone have a part number for the header panel and adapters?
New Overhead DVD player, Gray. wrong color for me. Found it in Chattanooga TN when driving home from Florida this weekend. I drive my wife nuts looking on craigslist for excursion parts In every town we drove thru.
