Sponsored by: Auxito
Help! Code P0172
Old Apr 25, 2016 | 12:11 PM
ZachManXLT's Avatar
ZachManXLT
Help! Code P0172
Alright guys so I've been battling this single code for the longest time now and it will not go away! I know for a fact that I do not have any leaking fuel injectors. I switched all of my bank one injectors over to my bank two to see if the code followed, but no luck. Please give me some suggestions! Thank you!
Old Apr 25, 2016 | 12:47 PM
pdqford's Avatar
pdqford
Does this model year use a vacuum controlled fuel pressure regulator?
Old Apr 25, 2016 | 03:25 PM
ZachManXLT's Avatar
ZachManXLT
Yes it does. I took the hose off to check for vacuum and it has plenty of it.
Old Apr 26, 2016 | 12:18 PM
pdqford's Avatar
pdqford
Has the FPR's vacuum diaphragm ruptured, allowing fuel into the vacuum hose?
Old May 7, 2017 | 11:05 AM
clyde418's Avatar
clyde418
2003 Expeditions 5.4 same issue with P0172.
What did you to solve your problem. Vacuum is good, new plugs, new injectors, coil packs 6 months old. Bank one is rich still.
Old May 7, 2017 | 11:25 AM
03-F150's Avatar
03-F150
I believe I had that code for my 2003 F-150. It turned out to be a dirty mass air sensor. I have a cold air intake kit and I had just cleaned and reoiled the filter. Guess I used too much oil. I pulled the mass air control module, not the entire tube piece. There are two screws (might be special kind heads) holding it in place. I used some throttle body cleaner with a cotton swab. Spray the swab and gently clean the delicate sensor. Also, bought a new air filter.
I think the code error I was getting was "running too lean".
Old Jun 5, 2017 | 02:22 AM
steve2003's Avatar
steve2003
same code p0172. 2003 xlt. a few other codes as well, but i cannot remember what they were. cleaned the mass air flow sensor but nothing changed. So, we replaced it with one from the junkyard and 3 or 4 codes including p0172 went away. so MAF sensor is my bet. at least worth a try cleaning it.
gibinez
1997 - 2003 F150
Nov 8, 2015 07:38 PM
camcam
Sep 28, 2013 06:41 PM
kellysteed
1997 - 2003 F150
Jul 20, 2010 01:56 PM
pdqford
Jun 5, 2009 10:02 AM
Jrock909
Sep 12, 2007 11:07 AM
