Abs sensor?
Old Apr 25, 2016 | 06:56 AM
Vince79vette's Avatar
Vince79vette
Abs sensor?
I have heard there are some problems about using the right sensor. I need the driver side abs sensor. Anyone have on they used that after market
Old Apr 25, 2016 | 08:30 AM
Bently_Coop's Avatar
Bently_Coop
The one that came on my Timken replacement bearing is working fine.
Old Apr 25, 2016 | 12:09 PM
Vince79vette
I dont need a whole bearing just the sensor and cant fine the correct part number
Old Apr 25, 2016 | 07:05 PM
Vince79vette
Any one else?
Old Apr 25, 2016 | 09:42 PM
Bently_Coop
Less than a minute of searching on Rock Auto:
Motorcraft for 4wd 2000 Excursion
More Information for MOTORCRAFT BRAB68
Motorcraft for 2wd right side
More Information for MOTORCRAFT BRAB67
Motorcraft for 2wd left side
More Information for MOTORCRAFT BRAB70
Old Apr 26, 2016 | 06:05 AM
Vince79vette
Guessing i will just have to try it and see. The pic doesnt look like my original one. Read some where that a few after market ones are shorter and dont work correctly and i have already had a few scares where my abs did not work and my brakes did not work. Thanks
Old Apr 26, 2016 | 07:02 AM
Vince79vette
I also found out why mine doesnt look like those. Didnt relize there is a blue plastic covering the sensor Name:  photo112.jpg
Old Apr 26, 2016 | 07:19 AM
Bently_Coop
I wonder how you get the plastic out of there with out damaging the bore.
The Timken sensor and OEM sensor worked fine on both of mine, I even use grease like the others.
Motorcraft is OEM too.
Old Apr 26, 2016 | 11:56 AM
Vince79vette
Im not sure. Hoping a pick maybe and pull it out. How much was your hub and sensor?
Old Apr 26, 2016 | 06:31 PM
WE3ZS's Avatar
WE3ZS
Your bakes did not work? A bad ABS sensor will not cause your brakes to not work, it could cause the ABS system to not perform properly and allow for the brakes to lock up but it wouldn't cause loss of brakes.
Old Apr 26, 2016 | 06:44 PM
Vince79vette
I thought the same thing. My breaks would try to abs stop(on off on off) so it wouldnt lock up but it wouldnt allow the pressure to make it to the brakes to stop. I unpluged the sensor and its stops fine. Plug the sensor back up and it happens again and cant stop. Tried it 3 times and same result. So its u pluged right now. Almost wrecked into on coming traffic at a light.
Old Apr 26, 2016 | 07:50 PM
Hkyplayr2's Avatar
Hkyplayr2
I just did these, well actually DzlDenny did this exact repair, along with calipers, rotors and pads, and it took a lot of patience to get the plastic ring out. We went to Autozone and got the ABS sensor for the drivers side and I have not had any issues since. Thanks Denny!!!
That was about a month ago I believe. If the Autozone ABS sensor fails in short order, I'll definitely be on here to let everyone know. My sensor was broke almost exactly like yours and I simply had brakes, not anti-lock, along with warped rotors, good times (drinks with lids only).
Old Apr 26, 2016 | 09:00 PM
Vince79vette
You remember how much the sensor was there? And how did u get the plastic out. Looks like a pain
Old Apr 26, 2016 | 09:20 PM
Hkyplayr2's Avatar
Hkyplayr2
$72 or so. Needle nose pliers, working it back and forth until it wiggled its way out.
Old Apr 27, 2016 | 06:40 AM
Vince79vette
Thanks man i will give it a try
pjnadon
Dec 19, 2010 10:58 AM
our911
Modular V10 (6.8l)
Aug 11, 2009 11:20 PM
sorensenj
1983 - 2012 Ranger & B-Series
Apr 12, 2004 11:26 AM
