Rig Modifications
Old Apr 25, 2016 | 06:18 AM
defyrftr's Avatar
defyrftr
Rig Modifications
Sailor Roy posted pictures of modifications he has done to his 5th wheel. Post pictures here for ideas.
I haven't done any yet but looking for inspiration
Old Apr 25, 2016 | 01:36 PM
Shovelheadrob's Avatar
Shovelheadrob
Ok I'll kick things off with a slide out rack to take one of my bikes.
Then inside we removed the jack knife sofa & the dinette & replaced them with some more comfortable furniture from local stores, saved some weight too.
Old Apr 25, 2016 | 02:09 PM
cferguson77's Avatar
cferguson77
That slide out bike rack is pretty slick!
Old Apr 25, 2016 | 03:06 PM
Shovelheadrob
Thanks, it takes around 10 minutes to fit the chequer plate & another 10 minutes to load the bike, although I haven't actually taken a bike with us yet, didn't see the point when we toured for a bit in the winter, but now that warmer weather is coming it should see some action this summer!
Old Apr 25, 2016 | 03:19 PM
RV_Tech's Avatar
RV_Tech
Jeez, I thought that was a possible seat for the Missus when she gets on my about my driving!
Steve
Old Apr 25, 2016 | 03:36 PM
defyrftr's Avatar
defyrftr
The only thing I have done is labeled some switches. Now if I can reverse the label so it is white letters on black vs black on white.
And after hearing the horror stories of connecting the city water connection to the flush, I painted the cap black.
Old Apr 26, 2016 | 09:21 AM
gasman6674's Avatar
gasman6674
Here are some of my mods
Added pull outs to the pantry, awning lights, flag holder, reels for water and power, screen protector and TV in the basement. Not pictured I have added a WiFi antenna to the top of the ladder replaced the too short stinky slinky tube with the fence post mod and a computer for all of my movies
Old Apr 26, 2016 | 05:36 PM
wingedone's Avatar
wingedone
Yes, very, very slick! I wish I could have done something like that for mine.
Old May 3, 2016 | 04:40 PM
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Active Streak: 30 Days
Mods......Montana FW
I have modified the tail lights on the Montana FW......
The standard tail lights are cheap incandescent fixtures from the 1900's.......
I added LED tail lamps.....I put them higher. Between the two lamps on each side, I would hope people will see me.
added light in the battery compartment
Switch on the door frame to turn light on - off.
There is the stock storage tube along side the frame........
Then I added a longer tube that is under the frame. goes the entire width under the trailer.
The new Storage Tube is adjustable in length.
Old May 3, 2016 | 04:49 PM
wingedone's Avatar
wingedone
Hey Roy, can you provide a reference or link to the sewer tube you added? Thanks!
Old May 3, 2016 | 07:11 PM
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Here it is:
Sanitubes / Sewer Hose Carriers / NEW!! SUPER-SLIDER Adjustable SUPER-TUBE - DW Inc.
Great service....arrived quickly.....The product looks good !!
Old May 3, 2016 | 08:11 PM
HRTKD's Avatar
HRTKD
Thanks for the link Roy. The toy hauler I'm in the process of buying doesn't have one.
Old May 4, 2016 | 12:06 AM
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
I have a 42 ft Raptor for sale.........
Old May 7, 2016 | 11:36 AM
Irelands child's Avatar
Irelands child
IF the weather ever gets to a point that I can work on our 5er without interruption, I have a workbench covered with 'things':
- Wet bolt kit (MORryde/Dexter)
- MORryde X-Factor suspension brace kits (3 of them)
- New 9/16" U bolts replacing the 1/2" (etrailer.com ) and a 1" tall aluminum stock homemade 'lift kit'
- ARP Norcold Fridge protector system (https://www.arprv.com/)
- LED taillights (same as Roy's) and LED bulbs (Superbright.com) for the existing taillight assemblies
- Back up camera (AMAZON low end but may swap to the Garmin matching the GPS)
Probably more, but these are the bigger ones.
Old May 15, 2016 | 10:45 PM
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
More lighting mods.....improvements........
Big LED light in the Battery Compartment.....controlled by switch on the door.
LED lights in the 2 Propane compartments.....door switch......
LED lights in/on the forward overhang........controlled by the switch on the factor light near the door of the battery compartment.
(BTW: That light is going to get a duplicate on the opposite side of the front panel.....ignore the blue lense....I was messing around.)
Also added a fused 30A terminal for power connections in that area of the FW.
Light OFF
Battery Compartment
Note: 2 of the LED Puck lights could not be recessed.....Structure in the way.
