Rig Modifications
Old May 16, 2016 | 07:16 AM
Irelands child's Avatar
Irelands child
Hey Roy, some great add ons, some of which I have done or on my list to do on our 5er.
Gotta ask - does yours have wet bolts with bronze bushings on the springs and MORryde equalizer? If not, you WILL need them if Lippert didn't supply them to Keystone with the frame. I installed the kit over the weekend on ours. Of the existing plastic bushings, there was only one that hadn't come apart/worn through in about 12K miles. I also put 9/16" U-bolts on the springs, replacing the scrawny 1/2" plus raised the unit with a 1" spacer. I also plan on installing three MORryde X-Factor cross members to strengthen the spring hangers but since I didn't do a good job measuring they need to wait in the corner of my garage until later as there is the rear gray tank drain and the main gas line that need to be shifted.
Old May 16, 2016 | 08:10 AM
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Active Streak: 30 Days
Hi Dave........
Yes......The FW comes with MORryde 3000.......Upgraded to the 4100. Yes, it has Wet Bolts.......Especially when it is raining.....
That reminds me.......The idiots ran the LP flex line to the Generator in a way that it will rub on the edge of the frame......
Easy enough of a fix.......shouldn't have to.
Old May 16, 2016 | 08:23 AM
Irelands child
Originally Posted by Sailor_Roy
Hi Dave........
The wonders of RV manufacturer's or dealers. You can probably bend the line out a bit if it's flex stuff then put some anti chafe around it. I had to do that for the stove and fridge line in one of the slides.
Old May 16, 2016 | 08:33 AM
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Stretched too tight to move. Fabric/rubber flex line. There is an Elbow that can be positioned different, that should solve the problem.
VegasFordSD
48
Jul 31, 2016 08:15 AM
Jrob69f100
Apr 7, 2016 11:30 PM
A/Ox4
Nov 21, 2014 10:43 PM
Snowking
17
Dec 16, 2008 10:04 PM
Snowking
20
Oct 20, 2008 10:21 PM
