E4OD what to look for?
Old Apr 28, 2016 | 10:11 PM
GuitarJesus's Avatar
GuitarJesus
Originally Posted by badasssapper67
I live around the Portland OR area.
Damn, it was taken down. A guy down here had a fresh Ford 97 reman on craigslist for $1200. It was for 2wd
Old Apr 29, 2016 | 12:09 AM
colemanw's Avatar
colemanw
What's the best expected mileage from a 92 3/4 ton hd e4od under light duty and regular maintenance before it would go **** up?
Old Apr 29, 2016 | 12:22 AM
GuitarJesus
Under light duty conditions you could get north of 200k easy. But light duty is a subjective thing.
Old Apr 29, 2016 | 12:31 AM
colemanw's Avatar
colemanw
So the 92s really arent all that comparatively bad? (light duty being freeway driving, little towing, and maintenance freak levels of maintenance.)
sorry for the thread hijack.
Old Apr 29, 2016 | 12:40 AM
GuitarJesus
Of maintained regularly and lightly driven, they should be fine. They stopped using the AOD and went to the e4od in the F150 and Bronco, so they figured with light duty usage it would do just fine
Old May 12, 2016 | 12:13 PM
badasssapper67's Avatar
badasssapper67
I've got one set of 5.13 gears sitting on the work bench waiting to be but on the dura grip diff I bought. I recon that it wont take long of me driving the truck into town to pick up some beer, and the OD tranny will become really important.
I mostly drive the truck around doing 45-50mph anyway but even then the C6-5.13's are going to be strong motivation for me to get the E4od into the truck. hahaha
Old May 12, 2016 | 12:15 PM
GuitarJesus
With 5.13's? I hope you have a gear vendor to go along with that. Otherwise you'll run out of gas before you hit town!
Old May 12, 2016 | 12:22 PM
badasssapper67
Hahaha. My life style is ULTRA rural. My land has a 1000' change in elevation on 18+ acres so I need the truck to be able to get around. It's going to stay a farm truck so I'll take the Mustang Cobra into town if I have to.
When I checked the rpm calculators, they said that 50 mph with 5.13's and .71 overdrive was somewhere around 2500 rpm's....if I remember correctly.... so we'll see.
I also am eyeballing a 514 ci stroker kit for the 460. Im trying to get that power stroke feel from a gas engine. I figure 10 "truck payments" at $750 a month and I'll have a truck custom made for me, plus I already own it, and it's not going to devalue any less than what I paid for it.
Old May 12, 2016 | 12:26 PM
badasssapper67
If I won the power ball, I'd get a 08-10 f350 with the 6.4 power stroke. Then I'd spend another 20-30grand souping it all up AND I wouldn't have to worry about being $60G into the truck and it devaluing to being worth $5G in twenty years.
But I aint going to win the power ball.
Old May 12, 2016 | 05:20 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
iv got 5.13's in my f450 with the e4od.around 45-50 mph i wish it had another gear.when i load the 16' bed and it still goes as easy as it did when empty,that's when i have no complaints.
Old May 12, 2016 | 06:01 PM
GuitarJesus
That's why I want 4.56 or 5.13 in my axles with a gear vendor. Towing a bigger trailer will be no hurdle (already bought an F-Super Duty larger master cylinder, reman Hydroboost unit and a Saginaw steering pump). With the higher lower end gearing, and a gear vendor for 8 gears, keeping things in the powerband and a favorable overdrive gear, I'll be all good.
67camaro
May 28, 2017 05:20 PM
wahlturfcare
20
Sep 16, 2016 08:43 PM
msorros
May 6, 2014 04:12 AM
big red c222
Mar 20, 2007 10:13 AM
greystreak92
1978 - 1996 Big Bronco
16
Jul 30, 2006 11:26 PM
