Engine choice
Old Apr 22, 2016 | 08:51 AM
bigmark's Avatar
bigmark
Engine choice
I have a 48 ford COE and thinking of what engine to put in it. I will use it just to run to the store and car shows sometimes. It will be a pickup not a car hauler. So I like to know what your thoughts are for ford engines?
Old Apr 22, 2016 | 09:46 AM
toby tough's Avatar
toby tough
I'd drop a 351 or 390 maybe in that bad boy. Give it a little giddyup and not be too bad on mpg's. It's your truck though so put whatever in there that works for you. Not suggesting but you could go to the (eew) darkside too.:-wink
Old Apr 22, 2016 | 01:03 PM
Allen T.'s Avatar
Allen T.
I don't have a COE, but can I tell you my F1 is going to get a 393w. Take a .030 bore 351w, buy the crankshaft from summit racing for $399, use stock 351w rods, and 302 pistons. It's light, makes torque out the wazoo, and parts are inexpensive and readily available.
Old Apr 22, 2016 | 08:08 PM
Stephen67's Avatar
Stephen67
I have an F600, put a lot of thought into this question myself.
I decided on a 460 with a ZF5 transmission.
Diesel isn't the best for quick short trips and the maintenance and initial costs only really pay for themselves if you do a lot of hauling. While a smaller gas motor might get better MPG in a smaller truck, a larger truck will work a bigger engine less than a smaller one, so you might as well have the power since you're stuck with the MPG. You can find ones built up a bit fairly inexpensive. Parts are cheap and plentiful. Just note that not all are equally as good and you can get one built up for only a little more than something factory.
The ZF5 has a granny gear as well as an overdrive.
5.4 Triton is a good choice as well, but it's more of a smaller truck engine, not a COE. Might be happy in the COE if you're not going to use it hard but they will be more expensive and more work to put in. Plus computers. A lot of money and work for a couple more MPGs over a 460 without the power of a 460.
Old Apr 22, 2016 | 10:20 PM
bigmark's Avatar
bigmark
Thanks for the input I was looking at a 351w or a 7.3 diesel did not even thinking about the big blocks. I don't think I will go with a diesel because I was thinking the same as stephen67 the short trips and maintenance.
Old Apr 23, 2016 | 12:46 AM
Jules The Great's Avatar
Jules The Great
I am putting a 5.4L DOHC lincoln navigator engine in my 55 F250. I hope to put a 4.6 in a 48 frame with all CV parts one day. If I had a truck like yours I would go with a truck 5.4L or 6.2L they are plenty big enough even if you are going to tow. Anything you put in there will have way more power and torque than the original.
If you are not into the new Modular motors from Ford then a 351 is certainly a great choice too!
Old Apr 23, 2016 | 06:38 AM
pweng1's Avatar
pweng1
My 54 Coe has the 460 but I am going with 351m in my 48 and 51 Coes. I looked for a 7.3 diesel for one but give up because of the demand for them near me.Good luck with the build and show some pics.
Old Apr 23, 2016 | 06:51 AM
Jules The Great
Whoa you have two COEs? Sounds like you have one for me over there!
Old Apr 23, 2016 | 08:40 AM
tinman52's Avatar
tinman52
Welder User
Will the engine be up front in the stock location or behind the cab? Or?
Stock COE chassis or something else? Lowered or modified?
All of these things will dictate what will physically fit and how hard it will be to install.
Old Apr 23, 2016 | 08:46 AM
pweng1's Avatar
pweng1
3 Coes and 2 F1's
None for sale. What better way to motivate my 2 sons than to buy each a Coe. Of course my jealous wife wanted a smaller one so i got her an F1. When i wanted to buy another i asked her if she was going to learn to drive a stick and she said no so i told her i had better buy this one for an automatic. She thinks im such a nice husband.
Old Apr 23, 2016 | 04:36 PM
Jafo56's Avatar
Jafo56
It's old and simple, keep it that way ! 351 with a carb
Old Apr 23, 2016 | 04:43 PM
toby tough's Avatar
toby tough
My 98 5.4 has 278,xxx miles on it. still going strong but I don't think that I would want to swap one into an old truck. Above my skill level I think. Seems Allen T might have a good combo there.
Old Apr 24, 2016 | 09:28 AM
bigmark's Avatar
bigmark
My plan is to put on a different chassis and the engine in the front stock location and put air bags on it down the line. The chassis is still up in the air
Old Apr 24, 2016 | 09:33 AM
drptop70ss's Avatar
drptop70ss
While I cant contribute to the engine discussion I will say that after seeing the COE builds here if I can find one to build I will be putting the engine behind the cab. Some of the foot wells look so tight I cant see how a BB would leave enough room for pedals!
79F-1504x4
Mar 30, 2011 12:02 AM
59flatbedford
13
Jan 15, 2010 06:28 AM
65fordguy
Oct 19, 2007 10:18 PM
BlueOvalboy25
Feb 20, 2004 09:57 AM
carpe_diem
Nov 13, 2003 06:13 PM
