Thermostat
Old Apr 20, 2016 | 02:17 PM
smithm31's Avatar
smithm31
Thermostat
I am putting new Terminator thermostat from Riffraff in my F350 7.3. I have installed many thermostats in gas cars, but never a diesel truck. I am hoping that it is straight forward much like a gas car. Is their anything that is different? Do I need to purge the air out? If so ,is there a purge valve? Thanks
Old Apr 20, 2016 | 03:12 PM
farmert's Avatar
farmert
It is just like putting a thermostat in a gasser. The only difference is the thermostat housing neck. It is just tin, and is prone to leaking when removed and reinstalled. I always have to use a thin layer of RTV on the o-ring and base of the neck.
Old Apr 20, 2016 | 03:59 PM
fordpride's Avatar
fordpride
What year truck ? Cause there is a long and short stem t-stat
Old Apr 20, 2016 | 05:40 PM
smithm31's Avatar
smithm31
I pulled the thermostat housing off and removed the o-ring and cleaned the housing up and started to put housing and thermostat on and realized I couldn't remember if the o-ring goes under the thermostat or on top of it. In other words does the o-ring drop into groove and then thermostat sits on top of o-ring or does thermostat go into groove first and then o-ring? Can't believe I didn't make a note of how it went back together. I'm also replacing top and bottom radiator hoses and I'll be working on that until someone tells me how the o-ring goes back. Truck is a 1997.
Old Apr 20, 2016 | 05:51 PM
farmert's Avatar
farmert
I always go thermo. O-ring, neck.
Old Apr 21, 2016 | 06:24 AM
finallyo3gt's Avatar
finallyo3gt
+1 on the neck T-stat length. There are 2 floating around and at least 1 auto parts store sold me the wrong one. I'd have used it if not for researching on this forum. Also +1 on a thin layer of RTV, even with the o-ring. Chances are high that it will leak. Otherwise, just like a gaser.
Old Apr 21, 2016 | 07:16 AM
CampSpringsJohn's Avatar
CampSpringsJohn
The last t-stat I changed had a rubber o-ring that went around both sides of the thermostat. Oh, and every one I changed leaked. A new housing fixed every one.
Old Apr 21, 2016 | 09:54 AM
madpogue's Avatar
madpogue
Permanent fix for the flimsy t-stat housing/leak issue - https://www.strictlydiesel.com/p-267...sing-ring.aspx - also includes MUCH better quality bolts. And no stikkky stuff required.
Old Apr 21, 2016 | 11:21 AM
oldbird1965's Avatar
oldbird1965
x2^^^^^ on the link above!
fordguy2100
Ford Truck Parts for Sale
May 13, 2016 10:37 AM
timmygyu
1978 - 1996 Big Bronco
Oct 20, 2014 09:30 AM
z 97ford1
1997 - 2003 F150
Sep 24, 2014 05:19 PM
pullinair
Aug 18, 2006 06:40 PM
