E40d tranny
Old Apr 19, 2016 | 08:12 PM
Trevor English's Avatar
Trevor English
E40d tranny
I have a 93 flareside with a 5.0 and e40d trans. I had mine rebuild. Was fine but shifted hard in the into 2nd at times. Eventually it stopped moving in first it went but extremely slow so I'd have to put it in 2nd get up to speed then shift back up. Now thinking it was the trans I had a friend take his out and sell it to me with a shift kit in it. Same exact trans. Replaced it and it's now having the same issues. Torque converter was replaced when I had mine rebuilt about 2 months ago or a little over. What could this be something electrical?
Old Apr 19, 2016 | 08:23 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
high gear starts in the D position means the trans solenoids are not getting power.replacing the trans itself wont cure the problem unless you got lucky and the issue was the solenoid pack but of course that's much cheaper and easier to change than a whole trans.
manually selecting 1 or 2 without power to the trans will both = 2nd gear.this is why your able to take off ok while manually shifting and then shift into D once rolling.
restore power to the trans,and your problem will be gone.
Old Apr 19, 2016 | 08:40 PM
Lead Head's Avatar
Lead Head
Start by checking for error codes.
Old Apr 19, 2016 | 08:42 PM
toby tough's Avatar
toby tough
Check the fuse too.
Old Apr 19, 2016 | 09:02 PM
Trevor English
How do you replace the solenoid ??
1997fordf350
Feb 4, 2014 09:01 PM
MOERULES
Jun 27, 2008 07:47 AM
