Chassis questions
Old Apr 24, 2016 | 05:28 AM
threepiece's Avatar
threepiece
Originally Posted by ol'blue77
Anyway......... after that is there like some special kind of paint I should put on it? like epoxy paint/acrylic paint.
I will caution you about products like POR15. They work great when applied on properly prepared surfaces but can be trouble if not. Be sure to follow the directions on the package. Taking short-cuts could cause more damage than coating with nothing at all.
Whatever paint/primer type product you use be sure to apply at least two coats AND a third and even fourth coat on rust pitted areas. I usually start by applying a coat to the area with the deepest pitting. After that area is sticky but does not transfer to my finger when I touch it I add a second,third and even fourth coat, ending with the areas with the least amount of pitting.
The "pinhole" type of pits are the most troublesome and require the most coats. Other pits are smooth like waves in the surface of a lake. These require fewer coats.
Old Apr 24, 2016 | 09:34 PM
grinnergetter's Avatar
grinnergetter
After going the powder coat and Chassis Saver routes I now would just epoxy prime and shoot a nice coat of whatever brand single stage you want. Keeping it simple means repairs to the finish are simple too. Stuff happens.
Old Apr 27, 2016 | 03:10 PM
olblue77's Avatar
olblue77
Alright guys thanks for the help
Old Apr 27, 2016 | 04:07 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
VIN says it came from the factory with a 302.
Look at this pic (upper) for 6A023 .. this is the rear engine support bracket (some people call a cross member) that the rear motor (trans) mount (6068) bolts to.
As you can see it bolts on. Trans shop probably cut it out to save time.
D6TZ-6A023-A .. Rear Support / Obsolete
Applications: 1976/79 F100 302 M/T & C4 / 1976/78 F100/250 Regular Cab 2WD 300 I-6 / 1977 F150 302 M/T & C4 / 1977 F250 4WD 300 I-6 / 1977 F350 Regular Cab 300 I-6.
1977/79 F100/250 Regular Cab 351M/400 2WD M/T / 1979 F100/150 2WD Regular Cab 300 I-6 C4 / 1979 F100/250 Regular Cab 2WD 300 I-6 M/T
Old Apr 27, 2016 | 11:28 PM
olblue77's Avatar
olblue77
The "crossmember" they cut out is in between the 6A023 and the engine block mounts. I'm sure they cut it out so they wouldn't have to pull the engine (like you said; to save time). The rear motor/trans mount is still there in perfect condition. I'll get pics tomorrow if that will help. It's directly below where the bellhousing would sit.
Thanks for the pictures though, that breaks everything down on the chassis and gives me a more in depth view on it.
Old Apr 28, 2016 | 01:44 PM
NumberDummy
6A023 rear engine support bracket not shown in upper pic.
D3TZ-5025-A .. #2 Cross Member / Obsolete
Applications: 1973/79 F100/250 2WD Regular Cab / 1975/79 F150 2WD Regular Cab.
GREEN SALES CO. in Cincinnati OH has 1 = 800-543-4959.
MCDONALD OBSOLETE PARTS CO. in Rockport IN has 1 = 812-359-4965.
Old Apr 28, 2016 | 11:01 PM
olblue77's Avatar
olblue77
Sweet thanks for the help man.
Another question I was wanting to ask, do you know anything about the seat belt light? My truck's trim is custom I believe. I was kind of wanting to get that working again. Someone cut the wire leading to the seat belt buckle and I have no idea about it.
Old Apr 29, 2016 | 11:53 AM
NumberDummy
Look at this picture at lower left for basic part number 10B924 = Seat Belt Warning Indicator Switch which includes the buzzer.
D6AZ-10B924-B (Motorcraft SW-1387) .. 1978/79 F100/350, Bronco & Econoline...but not all these vehicles came with it.
You'll have to look behind the dash to see if your truck has it.
Uni Moe
Sep 27, 2014 11:27 PM
richardgillham
May 7, 2013 08:18 AM
tatnic2
Aug 7, 2007 02:31 PM
Moneypit 56
Feb 21, 2005 07:47 PM
Umpqua Arms
Mar 6, 2003 12:36 AM
