Hard to start when hot
Old 04-21-2016, 07:31 AM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,194 Likes on 943 Posts
Originally Posted by Mbizzal
I would assume so.
I watch this TV show called Wheeler Dealers on the Velocity channel. In one of the shows the mechanic used this system to clean the carbon out of a car, injectors included. It appeared to work very well.
Does anyone know if there is a way to clean the injectors (professionally) without having to remove the injectors? I don't mind paying a bit more if I don't have to remove the injectors.
https://www.ford-trucks.com/forums/1...l#post14909075
Old 04-21-2016, 08:11 AM
Mbizzal's Avatar
Mbizzal
Mbizzal is offline
Thanks rla2005 I appreciate the link. I will give that a shot if I can't find a repair/service shop that can do it. I would rather a professional service shop do it. But, if not I will try what the link shows.
This has been a lot of good info.
Old 04-22-2016, 07:15 AM
Mbizzal's Avatar
Mbizzal
Mbizzal is offline
I will be bringing the truck in to a Ford dealer. They will do the three step system and hopefully that will help with the issue. While I am there I am going to buy a fuel pressure regulator and Temp sensor for the computer.
Ford is charging $129.00 for the cleaning and I will have them change the oil as well.
Wish me luck and I will post on how things go.
Old 04-25-2016, 07:05 AM
Mbizzal's Avatar
Mbizzal
Mbizzal is offline
The fuel system cleaner appears to have helped if not fixed the issue. I used my truck all weekend and no hard start problem. It sat from 1 hour to 6 hours and no issue.
The mechanic (Older Fellow) said that I should change the Coolant temp sensor also. He said back in the day that the temp sensor would also cause a starting issue. I wanted to buy one at the Ford dealer ship but the guy behind the counter didn't seem to know what his job was (finding parts) and couldn't find the correct sensor.
The mechanic said I need the sensor that sends the signal to the computer, so don't buy the sending unit.
Looking at Rockauto I can see the confusion. Does anyone know what sensor I need? There are tons of sensors out there.
Old 04-25-2016, 07:45 AM
rla2005's Avatar
rla2005
rla2005 is offline
Is there a code for a sensor out of range? I would not throw parts at this. Many aftermarket parts suffer from poor quality control.
Use a DVM to verify if yours is reading correctly: Engine Coolant Temperature sensor
courtesy of Subford
Old 04-25-2016, 07:56 AM
Mbizzal's Avatar
Mbizzal
Mbizzal is offline
RLA2005
No trouble codes are being thrown. The tester continues with 111.
You are probably right. The truck seems to be running better, no need to add a part that appears to be working fine.
The only reason I was thinking of changing the sensor is because the poor quality of coolant that was in the truck before I changed it. It was brown and the thermostat didn't look any better. I am not sure if poor quality coolant would cause the sensor to read incorrectly but continue to show not fault codes. I guess I could just pull the ECT out and check its condition.
Thanks again for the info, I really appreciate it.
Old 06-13-2016, 09:42 AM
Mbizzal's Avatar
Mbizzal
Mbizzal is offline
Does anyone have a part number for the ECT sensor? I seem to be getting different part numbers for the ECT and coolant sending unit.
I would like to order a new one.
Old 06-13-2016, 12:49 PM
rla2005's Avatar
rla2005
rla2005 is offline
Motorcraft DY1144
Alternate/OEM Part Number(s): 3F1Z12A648A, 5TE9176AA, DY961, F5AF12A648AB, F5AZ12A648AB
Old 06-14-2016, 07:07 AM
Mbizzal's Avatar
Mbizzal
Mbizzal is offline
Great, I just ordered a Motorcraft part.
Any idea if I need to drain a little coolant before I remove/replace the sensor? It appears to be higher than the radiator but I am not sure.
Thanks for the info.
Old 06-15-2016, 08:28 PM
east302's Avatar
east302
east302 is offline
I didn't drain any, but did lose a little when removing the sensor. Just have some rags and the new one ready to go.
Old 06-16-2016, 06:51 AM
Mbizzal's Avatar
Mbizzal
Mbizzal is offline
Thanks east302 I am glade to hear that. Makes it that much easier.
Thanks again
ChargerFan
1978 - 1996 Big Bronco
08-18-2016 02:36 AM
sean9049
01-30-2015 09:25 PM
jwcollin1
1997 - 2003 F150
01-31-2013 11:54 PM
dillehay
01-10-2013 08:28 PM
hotrod351
21
06-25-2011 07:41 AM
Quick Reply: Hard to start when hot
