7.3 towing
Old Aug 13, 2003 | 06:35 PM
state's Avatar
state
Question 7.3 towing
Should my completely stock 2003 Ex with a 7.3 PS have any trouble towing a 27ft, 7000 lb camper? I do have the brake controller. I might tow 4 or 5 times a year for up to 500 miles each way.
Old Aug 13, 2003 | 08:59 PM
jschira's Avatar
jschira
7.3 towing
I bought mine to tow 8000-8500 lbs.
Another poster uses his to pull a 41' TT.
You may need a sway control device.
You might also have more rear end squat than you want.
These are both easily fixed if needed.
Old Aug 14, 2003 | 04:57 AM
state's Avatar
state
7.3 towing
I have the sway control and the weight distributing hook-up. I was more concerned with engine power and transmission in stock form.
Old Aug 14, 2003 | 06:13 AM
jschira's Avatar
jschira
7.3 towing
7000 lbs. is nothing to the 7.3.
Many pull 13,000-15,000 lbs. with the 7.3 and 4R100 in a SD.
I pulled 5000 lbs. fairly easily with my '94 Dodge B-150 with a 5.2L gasser.
Old Aug 14, 2003 | 06:15 AM
f_pumillo's Avatar
f_pumillo
7.3 towing
You won't have a problem. I tow a 32' TT, about 8K. More power than you every had (unless you had another PSD). With the trailer I can keep up with traffic at 55, 60, 65, or 70. I try to stay between 65 and 68. The PSD gets a little bit better fuel economy and the EGT's and Trans temp stay a slight bit cooler. Other than that tow away. I did put guages on my X and invested int he SuperCHip Micro tuner. In tow safe mode it is a dream to drive and tow, lots of reserve power and just cruises away.
Old Aug 14, 2003 | 07:45 PM
opnekryan's Avatar
opnekryan
7.3 towing
7,000 lbs will be no prolem at all... I tow around 12-13000 lbs of dirt in a Dumptrailer everyday in my 7.3 PSD!!
Old Aug 20, 2003 | 11:06 AM
PSDLOVER's Avatar
PSDLOVER
7.3 towing
I hauled a 10K Llb Fifth Wheel all around the Rockies this summer through some really high passes and I was blown away at the ease with which the PSD did its job. I have modified it somewhat with a K&D filter and reprogrammed the computer but you will have no problems towing that TT I am sure.
Old Aug 26, 2003 | 10:57 AM
bigolbob's Avatar
bigolbob
7.3 towing
I have been towing a 9,000# trailer around the western US with a stock F250 PSD 4X4 and am very happy with the performance. Addmitted on 6 to 8% grades (uphill) it will slow down to 60 MPH and be maxed out on throttle but I can live with that. I could spend $$$$ to enhance the performance but I'm happy with it as is. (avg 11-12 MPG towing)
