Oil bath filter question
Old Apr 16, 2016 | 08:03 PM
wmcewan's Avatar
wmcewan
Hello all -
My name is Bill, and I'm new to the forum.
I picked up a '55 F100 this past weekend.
(It has the 223 I6.)
The oil bath filter was off and sitting on the bed.
Looking at the top of the carb, and the bottom of the oil bath filter housing, it's clear I'm missing something.
Can anyone show me what part is used to mate the housing to the carb?
Or even better, does anyone have any idea where I could get this part?
That "Mid Fifty" company doesn't seem to have much in the way of engine parts....
Thanks a lot!
- Bill
Old Apr 16, 2016 | 08:22 PM
52 Merc's Avatar
52 Merc
Welcome to the forum, Bill! As you've correctly surmised, you're missing the bottom half of the air cleaner assembly, the part that holds the oil. Here's some pictures of what you're missing that may help from an article I wrote on modifying one, several years ago. The air cleaners are listed on ebay all the time, and you may find one for your application at a local swap meet, as well. Keep your eyes open and they'll turn up.
https://www.ford-trucks.com/forums/1...r-cleaner.html
Old Apr 16, 2016 | 08:40 PM
ktgovols's Avatar
ktgovols
I saw one on eBay yesterday. This one is for a Yblock. Yours is a six. I don't know if they are the same or not, but you'll know where to start looking.
https://www.ebay.com/ulk/itm/162034710456
Good luck
Keith
Old Apr 16, 2016 | 10:11 PM
wmcewan's Avatar
wmcewan
Thank you Wayne, and thank you Keith.
I was intending to do the swap to a paper filter, so thanks for sharing your article. That's the clearest write-up I've seen yet on the process.
Almost too bad to pay ~$70 on eBay for the used part and then just hack it up.
Thanks again gentlemen.
Old Apr 16, 2016 | 11:31 PM
52 Merc's Avatar
52 Merc
The 6 is different from the V8, and the truck cleaner is different from the car unit. The air horn on the carb has a different shape, so only the 6 cylinder truck air cleaner will work with your carb.
Old Apr 17, 2016 | 07:38 AM
wmcewan's Avatar
wmcewan
No kidding, I would have thought with that compression fit / screw setup I could have gotten away with anything that had a similar measurement on the ID. (especially since I am going to convert it to paper anyway)
Thanks again Wayne, you likely saved me a purchase / sell-back on eBay.
Old Apr 17, 2016 | 08:27 AM
38 coupe's Avatar
38 coupe
Actually the cars and trucks used the same carburetor on the six cylinders. Unlike the V8s the air horn is cast into the carburetor body. So with the six cylinders the car air cleaner will install on a truck, and vise versa. As mentioned above, the six and V8 use a different diameter where the air cleaner clamps onto the carburetor. You will need a six cylinder air cleaner.
I personally like the oil bath. I see no reason to convert to paper. Just my 2¢s.
Old Apr 17, 2016 | 11:14 AM
wmcewan's Avatar
wmcewan
Thanks Fred.
I think I found one, but I would have expected to see a screw for tightening the bottom of the filter housing to the top of the carb.
Maybe this too is incomplete?
1956 Ford 6 Cylinder Oil Bath Air Cleaner | eBay
Old Apr 17, 2016 | 11:21 AM
raytasch's Avatar
raytasch
Believe Nothing
Originally Posted by wmcewan
Thanks Fred.
The clamp assembly appears to be missing from that unit. Someone on here will have what you need.
Old Apr 17, 2016 | 11:49 AM
Mixer man's Avatar
Mixer man
I believe that air cleaner requires a stud in the carburetor air horn. A base clamp is not used on this style.
52 Merc's Avatar
52 Merc
Ray's right. That one is incomplete. I'd pass if it were me and wait for a better one.
Edit; or if Bob is right, it's the wrong unit for your application. Either way I don't think you want that one.
Old Apr 17, 2016 | 02:30 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
FoMoCo replacement =
C2UZ-9600-B (replaced C1TZ-9600-B & B6A-9600-A & 8MTH-9600-A) .. Oil Bath Air Cleaner 9.06" O.D. x 3.75" high / 2 13/16" nominal carburetor mounting flange / Use without brace / Obsolete
1948/51 F1/F6 226 I-6 (flathead) / 1952 F1/F6 215 I-6 / 1953 F100/600 215 I-6 / 1954/60 F100/600 223 I-6 / 1961/62 Econoline 144/170 I-6 / 1952/56 Ford Passenger Cars 215/223 I-6.
Old Apr 17, 2016 | 03:43 PM
Mixer man's Avatar
Mixer man
This is the type of air cleaner you are looking for, with the bottom wedge clamp. This is for illustration purposes only.
1951 Ford F1 V8 Original Oil Bath Breather | eBay
Old Apr 17, 2016 | 05:48 PM
wmcewan's Avatar
wmcewan
Thanks Bob. I don't have that arch with the threaded hole on the top of the carb, and I don't see any place where it might have broken off. My carb is definitely different than the example picture you used, so I'm hoping I don't need a new carb, and the oil bath filter I'm looking for clamps on.
The "example" you sent from eBay (off a V8) looks right to me based on my research.
Thanks for the part numbers Bill.
I've scoured the whole internet, and I don't think there's a verified part out there currently - but I'll keep searching eBay and CL until something shows up.
Thanks everyone - this site is awesome!
Old Apr 17, 2016 | 05:56 PM
wmcewan's Avatar
wmcewan
This item looks the part, and it does list an ID of 2 1/4" which is dead-on the exact measurement I took from my carb.
I asked the seller what he pulled it from, let's see if he knows...
http://www.ebay.com/itm/182093058348?item=182093058348&viewitem=&vxp=mtr
