Efi 351 backfiring
Old Apr 16, 2016 | 02:28 PM
Fordking26's Avatar
Fordking26
Efi 351 backfiring
94 f350 5 speed 4x4 70,000 miles 351 5.8
Truck will backfire at return of throttle to almost ide position or after shifts. Runs strong and as it should when cold, replaced air intake sensor no change, unplug the air intake sensor and seems to run as it should with no backfire, have also cleaned throttle body, and replaced spark plugs, has enough power to drive bust still think that it should have more. Any ideals??
Old Apr 16, 2016 | 03:43 PM
Conanski's Avatar
Conanski
Could be a lot of things. Start by pulling codes, if this comes back all clear(code 111) then don't waste another second with anything EFI related, look instead at the non computer controlled things like spark plug routing and crossfiring(run the engine in the dark with all the light off), and do a compression and leak down test. Also test fuel pressure at the rail, should be 32-35psi at idle and it should jump to 39-45psi with vacuum removed from the regulator or when the throttle is goosed.
Old Apr 16, 2016 | 03:46 PM
Fordking26's Avatar
Fordking26
It's just throwing me off that the air intake temperature sensor is unplugged and seems to run like it should, but when replaced with new sensor and plugged in has the same backfiring issue.
Old Apr 17, 2016 | 09:32 PM
Lead Head's Avatar
Lead Head
When you say backfiring, do you mean you're getting popping out of the exhaust, or popping/backfiring out of the intake?
Old Apr 18, 2016 | 08:35 AM
Conanski's Avatar
Conanski
This is a computer controlled fuel system and it would seem you don't quite understand how it works, that's not a jab at you most people don't understand EFI too well, so don't guess at the cause of the problem pull the codes and then you will know what the computer knows and you can make an informed decision on what your next move is.. with help from members here of course.
Old Apr 18, 2016 | 03:00 PM
BuickBrian's Avatar
BuickBrian
Have you checked the ignition timing? Retarded timing will cause low power and backfiring just like you are describing.
Old Apr 18, 2016 | 11:15 PM
92bronco4.9's Avatar
92bronco4.9
Had this problem. check your ignition control module
Old Apr 22, 2016 | 09:21 AM
Fordking26's Avatar
Fordking26
Just one mabey 2 loud bangs out of the exaust only at mabey a half an inch from idle position of pedal
Old May 7, 2016 | 08:03 PM
Fordking26's Avatar
Fordking26
How do I go about checking this?
Old May 7, 2016 | 08:06 PM
Fordking26's Avatar
Fordking26
Also I have now replaced, throttle position sensor, air intake temp sensor, coolant temp sensor, fuel pressure regulator, fan clutch,
Old May 8, 2016 | 01:20 PM
jaagen's Avatar
jaagen
STOP what your doing and check CODES. Your just throwing money at it hoping and praying I'll work. PULL THE CODE before going any further.
Old May 8, 2016 | 01:23 PM
Fordking26's Avatar
Fordking26
You are correct, but have also had all codes pulled and replaced these parts due to the codes shown, only thing I haven't tackled yet is egr code.
Old May 8, 2016 | 03:13 PM
jaagen's Avatar
jaagen
Ok post the code you got and the peeps here will point you in the proper direction.
Old May 8, 2016 | 03:56 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Were they active codes or stored? Did you try erasing the codes and see what codes come back? Even if the codes are there you should check the part to see if is actually bad before replacing it. Throwing parts at the truck gets really expensive.
Old May 8, 2016 | 03:58 PM
Fordking26's Avatar
Fordking26
They were stored codes, didn't have any active.
Drake95
Jun 16, 2017 10:27 AM
alie-r
13
Jun 5, 2012 01:50 PM
Econoline 150
16
Nov 30, 2010 08:17 PM
jdj0716
Aug 5, 2010 10:50 PM
