My '91 300EFI has a bad stumbling problem except when you hammer it; and at idle (only in park) the RPMS drop to the point it almost stalls, then shoots up. You put her in drive, it doesnt do that.
I have new fuel filter, put on a TPS (throttle positioning sensor) and a new MAP sensor. They plugged my van in at the auto parts store cant get a fault reading.
Any ideas ?
Any ideas ?
If the folks at the parts store are agreeable, try a wiggle test. Plug in the scanner and follow the instructions for the test. Wiggling the wires on the sensors can sometimes reveal a bad connector.
I agree with AB, though. sounds a lot like a vacuum leak. check the intake manifold gasket and every place air can get into the intake.
pull the throttle body off and give it a good cleaning ! you have carbon build up around the butterflies and that is not letting enough air in at idol !
Thanks, you think it could be a Idle Air Control ?
Any ideas ?
Today I did just that; it was N-A-S-T-Y, I went through 2 throttle body/carb cleaner jumbo cans
It seemed to run better but at idle it still fluctuates and stumbles when accelerating (though it seems to be doing better)
Any other ideas ? I really like this old van, but its pushing my patience
pour 4 OZ of acetone /nail polish remover in the tank believe me it works makes the injectors like new in one tank i saw noticable performance in about 50 miles of driving
try a clifford 270 cam ...i have owned four f150s all with the 4.9 -6 and the one i just bought is the only one that does not stumble in the low end has this cam ....cam it.... if you read most all EFI f 150s have this problem ...the fuel mixture in the low end rpms it to rich the clifford cam corrects this other cams may also
Ok guys, here's a new one: my 94 stumbles and stalls until it finally dies unless you either give it fuel or put the transmission in P or N to let the engine s' rpms raise back up.....the kicker? It only does this occasionally when I stop at say, a stop sign, red light, etc.....And now it's developed into doing it every time I put it into reverse....Any info is appreciated
