'87 4.9L to replace '96 4.9L Engine Swap?
So you want to use the '87 engine in the '96?
The easiest way to go about it is to unbolt everything from the '96 block, and bolt it onto the '87 block. Intake manifold, exhaust manifold, all the wiring and all the sensors. You will also have to swap the front cover and crank pulley, since the 1996 has a special crank sensor and trigger wheel that the '87 doesn't have.
SKLSOUT
11-16-2017 01:48 AM
