What is wrong
Old Apr 14, 2016 | 08:06 PM
Boodrow379's Avatar
Boodrow379
What is wrong
Hey guys.. I was the one with the problem with the truck not starting.. Took a lot of work but I got it all fixed. Like I said this truck has been sitting for years and has about 300000 miles on it. When I first got the truck running it was burning a lot of oil, like a gallon every 50 miles.. Now it's burning about twice that and when I start it in the morning oil comes out the downpipe. I think it's the turbo.. But what do you guys think it is and what do I do about it?
Old Apr 14, 2016 | 08:10 PM
z31freakify's Avatar
z31freakify
Two possibilities, turbo or injector O rings or a combination of the two
Old Apr 14, 2016 | 08:11 PM
z31freakify
Take the down pipe and see if its full of oil.
Old Apr 14, 2016 | 09:52 PM
fordpride's Avatar
fordpride
That much oil in 50 miles then I'd say turbo seal
Old Apr 15, 2016 | 01:29 AM
Boodrow379's Avatar
Boodrow379
Ok.. I just put all brand new injector orings today because oil was going back into my fuel and injectors were loosing prime etc.. So how do I approach the turbo seal.. Change it or get a new turbo?
Old Apr 15, 2016 | 06:38 AM
fordpride's Avatar
fordpride
Rebuild kit for the turbo
Old Apr 15, 2016 | 10:11 AM
z31freakify
Check spturboost.com great prices and customer service top notch, contact Kevin for any Q.
Old Apr 17, 2016 | 12:06 AM
Boodrow379's Avatar
Boodrow379
Alright guys.. So I guess the o rings stopped it from burning oil lol.. Drive it about 150 miles and it didn't burn any oil. But I have a new problem. The truck doesn't want to go over 2400-2600 rpm.. It runs good until then and just acts like it's not getting fuel and the turbo stops winding up.. It gets worse as the gears go up for example when it's in overdrive it really doesn't want to go ever 70. No codes at all. It has a low pressure ebv code and I did what it took and fixed that.. New ipr, new icp, new valve cover gaskets, clean fuel filter, fuel filter clean and stays full of fuel.. I'm at a loss here what should i try or do ...?
Old Apr 17, 2016 | 04:21 AM
97-psd's Avatar
97-psd
Try revving it up with it in park. If it stutters and won't go over 2200-2500 Rpm you probably need injector o rings
Old Apr 17, 2016 | 08:36 AM
Boodrow379's Avatar
Boodrow379
Originally Posted by 97-psd
Try revving it up with it in park. If it stutters and won't go over 2200-2500 Roma you probably need injector o rings
It will rev to 4000 quick in park
dant
Oct 1, 2015 11:00 PM
Mars57
Feb 10, 2015 11:03 AM
Andrew010
6.7L Power Stroke Diesel
25
Feb 3, 2014 07:48 PM
460429_freak
Sep 27, 2007 03:27 PM
jsdobson
Aug 8, 2004 11:57 AM
