Need assistance with codes?
Old Aug 13, 2003 | 12:45 PM
Tectron1's Avatar
Tectron1
I recently took my truck in to have the AC charged and he pulled the codes for me since my check engine light had been cominng on, These are the codes that came up. His handwriting looks like a doctors so bear with me.
675 electric preasure control driver open
211 profile ICM pickup eratic
332 egr vac. not-open
628 -no explanation
The vacum controled sensor located under the egr valve closest to the front of the engine makes a buzzing sound sometimes after I shut the motor off, I also have a restictor plate with a 1/8 inch hole between the egr and manifold, but this has never caused a problem in the past.
I have a chilton but it doesnt seem to help me to much.
Thanks
Old Aug 13, 2003 | 08:33 PM
kevin122's Avatar
kevin122
this web sight will show what the code is http://autorepair.about.com/library/...-dtcs-main.htm
Old Aug 14, 2003 | 08:07 AM
Tectron1's Avatar
Tectron1
I'll check that out
thanks
Old Aug 14, 2003 | 10:11 AM
Tectron1's Avatar
Tectron1
Question Need assistance with codes?
Ok I checked out that web site and this is what I found
675 Transmission Range sensor circuit voltage out of range. Hard fault present, vehicle is in Failure Mode Effects Management (FMEM).
628 Lock-up solenoid circuit failure, excessive clutch slippage.
These 2 codes concern me the most, The transmission seems to be working fine, I have a B&M shift improover box installed and and it still shifts good and firm,no slippage that I can feel? Its a E4OD by the way
211 PIP circuit failure.
I couldn't find any information about what or where this is. Is it part of the transmission circitry?
332 Insufficient EGR flow.
I suspect I know what is causing this.
Sais13579
Oct 24, 2024 04:22 PM
rdw516
Aug 27, 2013 12:22 AM
Chrisdrm10
Aug 6, 2012 06:25 PM
theguy_88
Jan 1, 2008 12:41 PM
blueharley
Mar 29, 2007 09:03 AM
