I see that there is a lot of questions about this subject. New build 390 engine. All new parts including a hi volume oil pump. I have the 15 lbs pressure that seems normal (to me that seems low, but that seems ok with most). Very little or no oil to the rockers. Question is how much oil should the rockers get? Rocker bolts are in the correct locations. Also how can I tell that motor is getting oil without waiting for catastrophe. I am new to FEs.
You confirmed my next un-wanted check. I see your posts on ford-trucks a lot with some great information. It will be a few days and I will let you know. Thanks for your reply.
You could pull the distributor and manually drive the pump until you can figure things out. You should have more pressure and plenty of oil to the rockers. No worry of hurting anything. A good 1/2 inch drill should give you plenty of oil pressure
I have an old modified distributor that I used with a drill motor for pre-oiling. There is very little pressure, but I can hear the oil returning to the pan and the oil filter fills quickly. I am using a new mechanical oil gauge, I didn't believe the electrical one. No oil is pumped to the rockers. New to FEs (I normally build Chevys, sorry about that. I was talked into this one) I was very careful to insure all the plugs were in and all the bolts were in the correct holes. I appreciate your help.
I have some experience with the FE engines. (Once owned 406 Tri-power, 428 Cobra-Jet and also two original SOHC 427 engines etc.)
FE-motors are notorious for low oil pressure at idle especially with the automatic transmission since the revs drop to like 500 rpm in 'D' if You have the stock converter. Hi-volume pump is the answer, just like You have installed. I would change the oil filter and see how it changes. I've see it happen. New oil filters are not perfect. Neither are new gauges.....
Thanks. I installed a new filter. I am starting to wonder about the oil flow I hear back into the pan. Makes me think I have good oil flow from the pump, but nothing to slow it down (create pressure) like bearings and such. It sounds like a lot of flow. Why would I have so much oil flow back to the pan?
I used a speed handle to drive the pump and had oil falling over the sides of the head and 40#+ pressure (standard pump). Manually rotate the motor and drive the oil pump. Seems you have a restriction somewhere, hope it turns out to be something very simple (usually does). Keep us posted.
If the bearings are correct to Your crank and You have a high-volume pump, and You installed a new filter...... I would make sure that the pressure readings are correct. At idle, when hot, 10 psi or little less still works and I would feel comfortable. As long as the pressure reaches at least 60 psi when revving up. The FE is a really good engine.
That is indeed an old rule.
This isn't some worn out old engine tho, it is a new build he has with a HV pump.
That being the case you should have + or - 15psi
80psi cold idle
55psi hot idle
65psi cruising at 2500rpms
40psi ultimate lowest at decel when hot.
If you are not in this area something is missing or incorrect. If it were a stock oil pump, I'd expect to see 25psi lower than this pretty much all across the board. If it were a worn out engine with a stock pump I'd expect another 5-10psi lower than that and would consider it normal.
I'd be looking for oil galley plugs, especially the one that resides behind the distributor. Priming the oil pump while inspecting the lifter valley or below where the distributor sits should aid your discovery.
Thanks everybody. This all gives me things to check. I had previously checked the galley plug inside/ behind the distributor and it is there. It looks deep in the hole, not with the surface of the casting. I replaced the galley plugs with a plug kit, so I think they are all there. Are you saying I should have 80psi cold or 15psi cold? I have the 15psi at the filter, but no oil on the top end. I will check the rocker shafts.
That is what my engine with a HV pump runs.
I could see you being *within* 15psi of any of those figures, but I've never seen a brand new engine with a HV pump run 15psi at idle.
Even the worn out FE's with a stock pump run more pressure at the filter when cold.
I'd question the gauge's accuracy but you say the rockers are getting no oil. They should be gushing pretty well and putting enough oil up there that you nee valve covers installed to contain it all.
