Water pump change
Old Apr 10, 2016 | 08:44 PM
MikeB 88's Avatar
MikeB 88
Water pump change
Plan on changing my water pump in the next day or two. Truck is a 2000 Ranger, 2.5L with 185,000+ miles. Just wondering if there are any hints/gotcha's that may not be in the manual.
Any advice on bleeding the coolant after I get it back together?
Thanks,
Old Apr 10, 2016 | 10:07 PM
Hank85713's Avatar
Hank85713
does it call for changing timing belt at the same time? Most 4 cyls do since you pull the timing cover to change the pump!
Old Apr 11, 2016 | 05:06 AM
MikeB 88's Avatar
MikeB 88
I will take a close look at it. It's been on the truck for roughly 50,000 miles.
Old Apr 11, 2016 | 07:48 AM
Hank85713's Avatar
Hank85713
well it was just a thought as most of these things are to be replaced at 75-100000 mile intervals and it is a PIA to have to do something after you had been in there recently to begin with.
Old Apr 14, 2016 | 03:06 PM
MikeB 88's Avatar
MikeB 88
Bleeding the coolant system was easier than I thought. The service manual I have says to disconnect a heater hose at the heater core and run the engine until coolant started running out. I disconnected a hose when I started refilling the radiator and could hear burbling from the open hose. Once I filled the radiator and degas bottle, it took no time at all for coolant to run out of the heater core.
Temps came up nice and got hot air from the vents in the cab. After it cooled down, it took about a couple cups to top off the coolant.
D_STICK
1978 - 1996 Big Bronco
Sep 17, 2024 06:31 AM
fastback89
2009 - 2014 F150
Jan 19, 2016 04:43 AM
wethugin87
Mar 2, 2006 02:48 PM
96rangersean
Apr 5, 2004 09:11 PM
matthewy8
Aug 8, 2002 07:02 PM
