Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Serpentine problems.
Old Apr 10, 2016 | 01:32 PM
thelonerang3r's Avatar
thelonerang3r
My serpentine belt popped off last night at about 80 miles an hour. It didn't break and there doesn't appear to be any unusual wear on it. I've replaced tensioner and idler pulleys and the belt. It appears tight and i can barely get a 90 degree twist out of it. Every time I try to turn the motor over it pops off. I'm out of ideas. Any help?
thelonerang3r
It's an 06 2.3L.
Old Apr 10, 2016 | 03:22 PM
got2bjoester's Avatar
got2bjoester
Two obvious but must-be-asked questions come to mind..
1. Is the serpentine routed correctly?
2. Is it installed upside-down?
If the above are not the issue, I would have a helper hit the starter in short surges (no start) to see where the belt is wandering out of it's track.
Old Apr 10, 2016 | 04:02 PM
thelonerang3r
Finally got someone out here that kinda knows what he's doing. He's saying it's too much drag in the water pump. Would make sense. Motors aren't my thing, but I'll try until I figure it out. Keeping my fingers crossed for now
Old Apr 10, 2016 | 07:11 PM
got2bjoester
Another thought - You replaced the idle bearing.... was it completely seated or could it be slightly out of alignment?
Old Apr 10, 2016 | 07:14 PM
thelonerang3r
It's fully seated. The old pulley had a little wobble. This one doesn't. The problem was there before the change and persisted after.
Old Apr 11, 2016 | 09:10 PM
bmuhlbach's Avatar
bmuhlbach
It could be the water pump going. I take it its a 4 cylinder
Old Apr 11, 2016 | 09:13 PM
thelonerang3r
Changed out the water pump today, and I'm mobile again. Wasn't completely shot but bad enough I guess. Also found out the bearing in the A/C compressor is starting to deteriorate.
Old Apr 12, 2016 | 04:05 AM
Dan Robertson's Avatar
Dan Robertson
If the cost to repair the AC is too high, (and you can live without it like we can in Northern Maine) I believe that a shorter belt is available that bypasses the AC.
gregom
Mar 19, 2012 02:07 AM
JamesHajek
24
Mar 12, 2012 06:55 PM
Dan Taylor
20
Feb 5, 2008 09:59 PM
RPinNEB
Aerostar
Dec 12, 2005 01:50 PM
Waves
1983 - 2012 Ranger & B-Series
Apr 10, 2004 09:16 AM
