Ok so I have a 2005 f250 6.0L. It is fully bulletproofed with ARP head studs. I am running a sct anarchy on street tune. My problem is that sometimes it is "puking" coolant from the degas bottle but only a drop every now and then around the cap; it drives fine, no trouble codes, the engine and trans temp is fine and it's not blowing white smoke it still blows black smoke, and there is no coolant smell just straight diesel. Any ideas of what might be causing it to puke a drop of coolant every now and then?
A Degass Bottle Pressure test would rule any concerns in or out don't want any PSI above 12
8-12psi would be considered normal do the test from a full cold soak to Hot 190+ with the Hammmer down
