Looking at an 87 F-250 7.5
Hey everyone,
This is my first post here. So let me start out with saying sorry, as this is probably the 500th thread like this on here... but anyway. Here it goes.
Looking at this truck:
1987 Ford F-250 Supercab Styleside 155" WB - WDC Global Exports | Auto dealership in Ontario, California | Everything you need to manage and market your dealership from search engine optimized car dealer websites to CRM and inventory management tools
87 F-250 with the 7.5. Odo showing 97k, and based on the condition of the truck from the photos, believe it to be true and not 197k. Its 2WD, and not sure on the tranny or gears- waiting to hear back from the seller to see if they know. Its an auto though.
Basically, I don't know much about this generation of trucks- more familiar with newer (1997+) ones. Any major faults with the drivetrain I should be worried about? I will be taking a chance and buying sight unseen (risky, I know- but for this amount of $ willing to take a chance.. CA is far from IL. And finding a rust free 30yr old anything around here ain't gonna happen).
Any problem areas I should request pics of? Any seals prone to leaking etc.
Will be using the truck mostly on pavement/gravel pulling some of my other cars around, and occasionally hauling loads but nothing extreme. Assuming it should be plenty capable (if not fast, but I have other stuff for that!). Probably will be used less than 5k miles/yr.
I'm sort of a touch,feel, hear and smell kinda fella. 6 grand site unseen is a huge leap of faith. With the 5er in the bed there is a very good chance that that mileage on the odo has turn at least once. The pics show a very decent truck for high price if you know anyone that could physically give it a once over for you the maybe. Though clean I be willing to bet that it's going to be in need of repairs. Ford makes the best trucks but at that age things just wear out. Let it go and find something closer to home that you can touch, they don't call them stealers (dealers) for nothing.
Part of me wants to hold out for a 4x4 as it will see winter duty occasionally. But with some weight in the bed and snow tires it should be ok. And from what I've seen, finding a really clean 4x4 from this era isn't easy- lots have been beat to s*** offroad
Truck is worth 3.5K. That clean engine bay is one tell tale sign of a true 95K.
Get yourself a finish panel with the red reflector (that's the correct one for the year), for those holes on the tailgate.
Some made in the US ones are available as reproductions @ $350.00.
Not buying this as an investment, but it does look like the previous generation trucks in this condition are pulling $10k+. Who knows maybe it will be worth something in another 10 years.
Well decided to go forward with it.. hopefully I don't get screwed! Lol. Also noticed the truck has Axle code 39- which I think is the 3.55 non-ltd slip. I won't be doing any off roading, but I think a limited slip would help with the snow right? Maybe a C9? I've read 2wd lockers + snow = bad. Simply put..
This would just be a back up winter vehicle- I have a 4x4 for daily use.
And yes, I was aware of that. Thought that was kinda cool. Are there negative implications of that I should know about?
I want to learn how to work on my own cars, and I figured this truck would be a good place to start. Not overly complicated, and no outdated, early EFI system to worry about (I have a 1987 Jaguar XJS with the 5.3L V12 and an early EFI system. PITA)
1-wheel drive.. yeah.. I will definitely need to fix that. Sounds like, since i'm 2wd, a limited slip is the way to go for snow.
That's a fair point. I was reading some more about when Ford switched over to the EFI and it seems like there was a pretty small number of 87 460s that were still carbureted- sometime during that first model year of this generation the switch was made. So that's kind of cool, even if the EFI was more efficient.
Just an update for you folks. I was actually able to get in touch with the owner of the truck before it was sold to the dealer. Mostly good news:
His father owned the truck in Florida since new, and his son (the last owner) took it to California. So it is genuinely a 97k mile southern truck. Doesn't burn oil, shifts fine, etc. Some problems: coolant leaking from the timing chain cover, and the valve that switches between the tanks is no good. But the rear tank and pump are only about 5 years old. Also he has been having trouble with the carb but wasn't sure what the issue was.
All in all, seems like a pretty solid truck that needs some TLC. Dealer told me it was "all in perfect working order" but I would be shocked if any of these problems were fixed.
Signed the paperwork today so hopefully will get it here in a couple weeks.
