6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Pipes
Old Apr 7, 2016 | 07:16 PM
dondolittle2's Avatar
dondolittle2
Pipes
Ok I got the exhaust pipe out after two hours. Installed the H&S Mini Max.
I want to remove the DPF and Catalytic Converter and replace with a straight pipe from the flange to the muffler. The questions are Can I do that and if I can what about the sensors? Do I leave them out or do I have to weld bungs in and replace them. Thanks for all the info you guys know everything. Can I cut the pipe off in front of the catalytic converter?
Old Apr 8, 2016 | 04:06 AM
bubbasz1's Avatar
bubbasz1
H&S doesn't need sensors plugged in, tape them off and tuck them up out of the way.
Old Apr 8, 2016 | 04:51 AM
dondolittle2
Thanks bubbasz1 I needed to hear that, I had read somewhere about the sensors but now can't find the thread,
Old Apr 11, 2016 | 05:17 AM
bubbasz1's Avatar
bubbasz1
No problem!
Old Apr 23, 2016 | 08:34 AM
langballs's Avatar
langballs
Sensors are needed for Edge tuners. But definitely tape/tiestrap those harnesses out of the way. A buddy of mine had one rub through on the frame and caused issues with reference voltage for other sensors on that circuit.
Rusty_S
Mar 16, 2021 10:07 PM
stroker870
17
Jun 2, 2009 01:03 PM
briank
May 31, 2008 02:58 PM
JohnAW
Exhaust Systems
Dec 13, 2004 03:08 PM
braineless
Exhaust Systems
Feb 26, 2004 08:33 PM
