Disk brake conversion kits ?
Old Aug 13, 2003 | 03:12 AM
71ranchero500's Avatar
71ranchero500
Question Disk brake conversion kits ?
I know they have kits for this but I’m having a hard time finding a good place to buy them for my 71 ford ranchero with a 302, if It's better to not buy akit, what parts would I need example: rotor, calipers ... I’m not sure of everything I need, I can change my brakes but never done anything like this before should I go to a junk yard and pull a setup off another car? if anyone can give me some info that would be great
Thanks
Old Aug 13, 2003 | 03:45 AM
Torque1st's Avatar
Torque1st
Posting Legend
Moved from 302 Engine Forum...
Old Aug 18, 2003 | 08:29 PM
DW2455's Avatar
DW2455
try going to salvage yard and getting disk brake set up off early 70's mustang? DW
Old Aug 18, 2003 | 09:51 PM
71ranchero500
Do you think that a station wagon would be the same? What parts should I go after? Everything or should I by some stuff new? Like rotors brakes and so on... will I need more than the calipers?
Old Aug 18, 2003 | 09:53 PM
71ranchero500
p.s ive never done this before ive only changed brakes so any info would be good web sites and so on
Old Aug 19, 2003 | 12:09 AM
DW2455's Avatar
DW2455
Well im not 100% you have options, you will definatly need the spindles, rotors, calipers, and pads, you may even need a proportioning valve and the master cylinder. i did the on a maverick once, most salvage yards have a parts interchange book, just figure out which modles you can raid, once you have your spindles on the car, you can then buy remanufactured parts to make it all new, you just buy the parts for what ever model car you got the spindles from. i'd start by looking at a 71 torino, or mustang with front disks and go from there. hope this helps some. DW
Old Aug 19, 2003 | 10:27 AM
71ranchero500
thanks it helps alot
