tail light not working
Old Apr 6, 2016 | 02:55 PM
WildHammer's Avatar
WildHammer
Not sure where to post this but I've got a 97 expe 5.4, one of the running tail lights aren't working. The bulb is fine, turn signal and brake light work fine, even changed tho bulb just incase, still no luck. Checked all the fuses and they all seem to be fine. it's only the right side tail light that doesn't seem to come on when I turn on the head lights
Old Apr 6, 2016 | 03:59 PM
WentzMetalWorks's Avatar
WentzMetalWorks
This thread definitely needs moved.
Check power and ground at the bulb. Power on Brown wire, Ground on Black.
Old Apr 6, 2016 | 04:37 PM
69cj's Avatar
69cj
And trace it back till you find power. Check all splices and plugs. Don't assume that because a plug is in all the way that it is conducting. Been there done that on a fuel gauge.
Old Apr 6, 2016 | 05:10 PM
WildHammer's Avatar
WildHammer
The bulb should have power, it does illuminate for the turn signal and brake light (which run off the same bulb and wire) could it be something else?
Old Apr 6, 2016 | 05:28 PM
WentzMetalWorks
Stop/Turn is on a separate power circuit than Tails. Both tails and the license plate lights share the same power circuit. All lights on the rear (minus the high mount brake lights) use the same ground.
Old Apr 7, 2016 | 07:10 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Thread moved.
Somewhere, a wire got cut, if nothing else is affected, and the stop/turn work.
Could it be that someone hooked up a trailer wire harness and hooked into something they shouldn't have?
Old Apr 7, 2016 | 03:24 PM
WildHammer's Avatar
WildHammer
Originally Posted by Krewat
Thread moved.
I've had the truck for awhile, bought it from some kid who didn't maintain it much, the oil filter was atleast 4 years old and the truck had the original plugs and coils still in it.. I don't think he modified any wiring harness. The problem just started recently for me tho
Old Apr 7, 2016 | 05:34 PM
krewat's Avatar
krewat
Interesting... make sure the ground from the plug socket to the chassis is good.
Old Apr 24, 2016 | 05:36 PM
WildHammer's Avatar
WildHammer
Would like to leave an update. There wasn't any power going through to the license plates lights and I'm guessing they are on the same circuit or something. I disconnected and bypassed them and ran the power straight into the running tail light connection, seems to be working fine for me like that.
Appreciate the advise though
crowndog1
2004 - 2008 F150
Apr 7, 2012 09:47 PM
furyus
Oct 20, 2009 12:07 AM
bout3fitty
Electrical Systems/Wiring
Dec 7, 2004 02:14 PM
shane43028
Aug 20, 2003 10:15 PM
Bronco2guy
Bronco II
15
Mar 25, 2003 07:02 PM
