Head Stud/Oil Separator interference
Old Apr 5, 2016 | 04:27 PM
dsltech83's Avatar
dsltech83
Putting a set of studs in an early 2003 6.0 after assembly I have found that the studs interfere with the oil separator under the valve cover. Has anyone ran into this on an early truck before? If so what was the remedy?
Old Apr 9, 2016 | 08:48 AM
Maxium4x4's Avatar
Maxium4x4
Did you get this figured out?
Old Apr 12, 2016 | 08:40 PM
dsltech83's Avatar
dsltech83
Ya ment to post that I went ahead and put it together, it is ok. I had initially set the valve cover on without the gasket to cover the engine for the night and found the lack of clearance. After adding the gasket, the seperator sets up against the studs but has very little pressure. Truck is assembled and out of the shop customer picked up truck this morning.
Old Apr 12, 2016 | 10:01 PM
Yahiko's Avatar
Yahiko
Cool. I don't have that year but it's good to know about that.
Sean <BR>
6.0L Tech Folder
Yahiko
Feb 8, 2016 05:08 PM
Toreador_Diesel
Feb 8, 2016 03:07 PM
chaser1602
Jan 3, 2016 10:01 AM
troy676
Jul 19, 2015 07:38 AM
Mac J
Mar 25, 2015 12:01 PM
