1966 - 1977 Early Broncos
E4od Swap
Old Aug 12, 2003 | 10:57 PM
Jelly Rolls's Avatar
Jelly Rolls
Post E4od Swap
I have '94 Bronco that I can use as a donor that has an E4OD transmission. Has anyone ever swapped this trans into an EB? It is quite a bit longer than the C6 and I'm worried about driveline angles. With 4.10 gears, I would like to have the overdrive.
Old Aug 14, 2003 | 12:36 PM
traildawg's Avatar
traildawg
E4od Swap
The E4OD has computer controlled shifting based on rpm, load, etc., so unless you're also swapping the matching efi engine and computer it won't work. There's also no adapter made for it to bolt to the D20 T-case.
Old Aug 14, 2003 | 08:10 PM
Jelly Rolls
E4od Swap
The 94 is complete and driveable, but no longer road worthy due to a rollover that crushed the cab. I plan on using the entire drivetrain (engine, trans, transfer case if necessary) and computer. For me, this is about the best way to get EFI/OD since decent salvage yards are few and far between in my area and aftermarket EFI/OD could run into several thousand dollars, which I can't afford. I'm wondering if this complete swap is feasible or if I should look for another way.
Old Aug 14, 2003 | 11:30 PM
traildawg's Avatar
traildawg
E4od Swap
The only problems I could foresee would be having to relocate or possibly fabricate a new transmission crossmember. Also, if memory serves me correctly the 1356 T-case is a lot bigger than the D-20, which could lead to frame rail/floor clearance problems. You'll also probably need to get custom driveshafts due to the overall length difference, but it would be hard to say for sure until you have it in and can make actual measurements.
You might want to try asking about this swap over at www.classicbroncos.com as they may be able to go into more detail than I can.
Old Aug 15, 2003 | 09:30 AM
Jelly Rolls
E4od Swap
Thanks for the help.
