HEAT issue!!!
Old Apr 4, 2016 | 09:33 PM
DOOM173's Avatar
DOOM173
Exclamation HEAT issue!!!
Has anyone else here ever had this issue?
Heat is blowing through my dash vents in front of the windshield with the controls OFF!
Old Apr 4, 2016 | 10:26 PM
harley4jcs's Avatar
harley4jcs
Vacuum leak
Old Apr 4, 2016 | 10:40 PM
DOOM173's Avatar
DOOM173
Question
Originally Posted by harley4jcs
Vacuum leak
If it was a vacuum leak would I have any other issues besides this?
Old Apr 4, 2016 | 10:47 PM
harley4jcs's Avatar
harley4jcs
YES , no auto on the hubs if you have them ??? It is always helpful to post what the heck you are working on OTHER than just an X
Old Apr 4, 2016 | 10:53 PM
DOOM173's Avatar
DOOM173
Thanks for the reply. The last time I used my 4 wheel drive it had an issue engaging.
So I guess I'll start tracking down a leak! Thank you sir!
By the way I have an 05 Eddie Bower Ex.
Old Apr 4, 2016 | 11:19 PM
harley4jcs's Avatar
harley4jcs
And I'm guessing a 6.8
Old Apr 4, 2016 | 11:21 PM
harley4jcs's Avatar
harley4jcs
PS: Look in the tech folders for instructions
Old Apr 4, 2016 | 11:30 PM
DOOM173's Avatar
DOOM173
Yes sir it's the 6.8! Is this a common issue?
Old Apr 4, 2016 | 11:39 PM
Apocalypse's Avatar
Apocalypse
Sure is I went with SS braided hub lines and love them, I'll never have a leak!
Old Apr 4, 2016 | 11:40 PM
DOOM173's Avatar
DOOM173
Thumbs up
I was hoping you would chime in
Can you please post a link? I'll order them tomorrow!
Old Apr 5, 2016 | 08:19 AM
Greenscobie86's Avatar
Greenscobie86
Take a cigar or cigarette and blow the smoke into one of the vacuum lines, you'll find your leak pretty quickly.
Old Apr 5, 2016 | 08:46 AM
WE3ZS's Avatar
WE3ZS
These other fine fellows have you well on the way to finding and fixing your vacuum leak(s) so I'll take this opportunity to point out that you can go to your " User CP" and fill out your signature to show your year, trim level, drivetrain, engine and any mods you have performed on it. That way the info will show up at the bottom of every one of your posts so folks will know what your working with when you ask questions.
And while you are in the "User CP" you can also fill in your location so folks can see where you are from, who knows, you might be neighbors with one of us who likes to spin wrenches and has a preference for cheap beer!
Old Apr 5, 2016 | 10:18 AM
holeshotwalt's Avatar
holeshotwalt
Plus you could show another pic or 2 of the Ultimate Maurader... hint, hint!
Here's a link for those hoses- http://www.dieselsite.com/1999-2004f...ofhosekit.aspx
Old Apr 6, 2016 | 07:03 AM
projectSHO89's Avatar
projectSHO89
Leaking hubs or tubing will affect the HVAC controls ONLY when you're trying to switch into or out of 4x4. At any other time, there's no vacuum applied to those components via the PVH solenoid so there's no opportunity for leakeage.
Your odds are better if you investigate the PVH solenoid itself as well as the rest of the vacuum supply system BEFORE the PVH solenoid for leaks.
Old Apr 6, 2016 | 07:17 AM
Watcher58's Avatar
Watcher58
Yep-I had to replace my vacuum actuator as well....on both of the ones I had. The AC defaults to the factory start mode which is the defroster. There is a youtube video on the subject of this Ford ESOF problem. Easy fix.
