Only overheats when towing
Old Apr 20, 2016 | 11:03 AM
navistarnut's Avatar
navistarnut
I'm still curious what happened with the OP.
A courtesy reply would be great.
Old Apr 21, 2016 | 08:17 AM
jlillie's Avatar
jlillie
Probably took it to a shop, got some seriously bad, gut wrenching (and most likely wrong) news and never bothered to look back at the thread she started where there are literally dozens of guys willing to spend their time and knowledge to help asking nothing in return except the satisfaction of being able to help.
Have I ever thanked you guys for helping me when i first got my truck?
I probably did but Thank You again anyway. Especially Rusty and Watson. Thank you.
Old Apr 11, 2017 | 10:41 AM
Angie Rich's Avatar
Angie Rich
Reading for help. Im trying to read and understand so i can fix my truck took a 4 hour trip in 13 h
plz help im trying to understand all this so i can check things on my truck i took a 4 hour trip in 13 hours overheating the hole time
Old Apr 11, 2017 | 10:53 AM
Angie Rich's Avatar
Angie Rich
Originally Posted by texastech_diesel
Is the EGR valve plugged in still (directions below)? Even if the cooler is deleted removing the valve can cause issues with the fan operation. Are you saying it's overheating because the gauge on the dashboard is pegging?
You really need some kind of OBDII gauge or scanner to read live data:
https://www.ford-trucks.com/forums/1...eral-info.html
It's an up-front investment that will protect you from being ripped off. If you get one and post the values that we ask for, the disagnostic ability of the forum is pretty impressive, up to and including some people who work full-time repairing Powerstroke engines.
I prefer the DashBoss if you use Apple products or Torque App if you use Android. Many people will tell you to get a Scan Gauge, but having used one of those originally I think it's capabilities are limited and it's much more difficult to use compared to the smartphone products. If you really want to burn some cash the Edge Insight CTS2 is pretty awesome. If for example, you get a DashBoss, you can post screenshots you take with your phone to the boards here, and we can look at the data and point you in a good direction, either for you to look at or for you to pass on to a mechanic.
The first thing I would so is see if the EGR valve is installed, and plugged in correctly. This being unplugged can cause the fan to not operate correctly, leading to your overheating.
Look in the area of the green circle on the right:
And make sure this connector is plugged in:
is this the same on all trucks
Old Apr 11, 2017 | 10:55 AM
Angie Rich's Avatar
Angie Rich
Hwlp me plz
Old Apr 11, 2017 | 03:10 PM
2006powerstroke90's Avatar
2006powerstroke90
This literally doesn't even make sense? You tried to take a 4 hour trip but ended up taking 13 hours and the engine was over heating the whole time?
Old Apr 11, 2017 | 03:18 PM
navistarnut
It's called reverse time travel. It actually takes longer to go a shorter distance.
That clear it up?
Old Apr 11, 2017 | 03:21 PM
navistarnut
Hwlp me plz
Glad to help if you can provide is some specifics about the truck, trip, etc.
I would suggest starting a new thread, this one died after the OP got it fixed or gave up. We will likely never know
Old Apr 11, 2017 | 04:03 PM
2006powerstroke90
That clear it up?
Got it!
Old Apr 11, 2017 | 04:08 PM
87crewdually's Avatar
87crewdually
I'm assuming the post means that a trip that normally would take 4 hours ended up taking 13 hrs due to the constant overheating issue.
Slamdunkpro
Sep 2, 2018 07:00 PM
ontarioford
Jul 12, 2017 04:33 PM
WhiteBeast-05-powers
Mar 12, 2016 08:13 PM
geeride
Sep 12, 2015 02:36 PM
pawizard
Apr 12, 2008 09:07 PM
