Installing 460 in 1950 f1 what p/s fits best
Old 04-04-2016, 12:08 PM
Squirlyjim's Avatar
Squirlyjim
Squirlyjim is offline
I'm putting a 460 in a f1 with straight axel looking to see what p/s you guys recommend. And what cross members work best seeing that everything is going to be a tight squeeze.
Old 04-04-2016, 12:15 PM
CharlieLed's Avatar
CharlieLed
CharlieLed is offline
The only OEM solution is the power assist that came on 56 F100s. There is a rather pricey aftermarket solution but it's effectiveness has been questioned by some. The most commonplace solution is the Toyota PS box.
Old 04-04-2016, 12:37 PM
artscott61's Avatar
artscott61
artscott61 is offline
I have the series 400 from ccp and or mid fifty. I would like to see someone put in electric pump.
Old 04-04-2016, 12:39 PM
Squirlyjim's Avatar
Squirlyjim
Thanks do you happen to know how the clearance is with a Toyota box does the engine have to be offset at all
Old 04-04-2016, 04:51 PM
CharlieLed's Avatar
CharlieLed
I don't have the measurements off hand but as I recall the Toyota box is virtually the same size as the stock box...maybe just a bit taller which won't affect engine clearance. Lots of guys here have the Toyota box so maybe one of them will chime in with more hard data...
This may also help https://www.ford-trucks.com/articles...8-1960-trucks/
goose1478
04-15-2014 05:10 PM
Kyles Flathead
05-26-2012 04:08 PM
hot51
06-08-2009 11:35 AM
Quick Reply: Installing 460 in 1950 f1 what p/s fits best
