NEED some help finding a brake part! please
Old Apr 3, 2016 | 03:32 PM
lance65's Avatar
lance65
I am working on my 69 F250 rear axle(D60) and the PO had the local Goodyear do the brakes and what an F'in MESS! They put 3" shoes on when it takes 2 1/2" shoes, the parking brakes were all wrong, when you pull the lever, the arm/cam would not expand the shoes, so off everything came...the passenger side went GREAT!, but the driver side is a different story...I need to find the center pin that hold the parking brake lever to the backing plate....they broke the head of this one off!!!. Now I know why they didnt hook up the e-brakes correctly...morons.
So I need help finding a new pin...or is this going to be a wrecking yard item only?? You'll see the pin Im talking about in the attached pic(right at the center top)
Old Apr 3, 2016 | 03:33 PM
lance65's Avatar
lance65
BTW, that is a "borrowed" pic from the internet.
Old Apr 3, 2016 | 07:00 PM
351Cleveland C4's Avatar
351Cleveland C4
I can't tell what you are referring too in the picture. But why can't you improvise? Use a bolt if you can, or go down to the hardware store and get a pin. Or get a brake hardware kit and see if it comes in it.
Old Apr 3, 2016 | 09:26 PM
lance65's Avatar
lance65
Thanks Garrett,
I actually fixed it. it is a serrated stud with a round head, the head was broken off, so I just welded the stud to the washer under it...worked perfectly.
Old Apr 3, 2016 | 10:23 PM
orich's Avatar
orich
The e-brake arm assembly and the small hardware goodie stuff, I saved from a few yrs. earlier when, I changed out the whole rear axle assembly and used the best backing plates. dumped the old back at PnP scrap box. Being these truck are so old one never know when a bolt head will pop off or other e-brake hard ware will break and the only source it the PnP Junk Yard for a fast fix. But the last 3 yrs we don't get many bumps or dents like 5 yrs ago..
Old Apr 4, 2016 | 04:11 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by lance65
I am working on my 69 F250 rear axle(D60) and the PO had the local Goodyear do the brakes and what an F'in MESS! They put 3" shoes on when it takes 2 1/2" shoes.
You sure about this brake shoe size? The fronts will be the same size as the rear. If optional front discs are present (2WD), the rear shoes are 12" x 2 1/2."
12" x 2 1/2" brakes shoes: 1967/72 F250 Camper Special (all 2WD); 1966/72 F250 4WD; 1966/72 F250 2WD with 7,500 lbs. GVW only.
12 1/8" x 2" brake shoes: 1967/72 F250 2WD except with 7,500 lbs. GVW
Here's the picture, look on the backside of the backing plate for 2027
D6TZ-2027-A (replaced C8TZ-2027-A & D3TZ-2027-A) .. Pin / 1/4" -28 x 1 3/4" long / Available from Ford
1968/79 F250 with 12" x 2 1/2" brakes / 1968/79 F350 with 12" x 3" brakes.
These come in a package, if the dealer has to order, you have to buy the entire quantity.
COLLEY FORD in Glendora CA has 1 =800-253-3807.
FORD OF UPLAND in Upland CA has 1 = 909-946-5555.
GALPIN FORD in Van Nuys CA has 2 = 818-778-2005.
FAIRVIEW FORD in San Berdoo CA has 3 = 909-884-9261.
DON SANDERSON FORD in Glendale AZ has 3 = 623-842-8643.
GREEN SALES CO. in Cincinnati OH has 30 = 800-543-4959.
CougarJohn
General Automotive Discussion
Jan 26, 2018 07:05 AM
cr0wjane
Oct 16, 2017 06:43 AM
GuitarJesus
May 2, 2017 11:17 PM
Raksj04
1983 - 2012 Ranger & B-Series
Jun 5, 2014 06:59 AM
95f2504x4
15
May 4, 2012 11:57 PM
