1978 - 1996 Big Bronco
1994 bronco engine specs?
Old Aug 12, 2003 | 09:15 PM
iggy1982's Avatar
iggy1982
Question 1994 bronco engine specs?
can anyone post a link or tell me where i can get complete engine specs(bore, stroke, cam lift, duration, etc) for my 1994 ford bronco 5.0 engine?
Old Aug 13, 2003 | 05:04 PM
DeGideo's Avatar
DeGideo
The 1994 5.0L(302) truck engine has a 4.00" bore x 3.00" stroke, 9.0:1 compression ratio, and a factory roller camshaft with the following specs : 198 intake/200 exhaust degrees duration@.050" lift and .422" intake/.448"exhaust valve lift. Stock rocker arms are 1.6 ratio. Factory ratings for the 1994 version of this engine were : 205 net horsepower4,000rpm & 275 lbs./ft. of torque@3,000rpm with a manual tranny. With an automatic behind it the ratings were 199@4,000rpm / 270 lbs./ft.@3,000rpm.
Old Aug 13, 2003 | 05:30 PM
iggy1982's Avatar
iggy1982
Exclamation 1994 bronco engine specs?
ok thank you but where did that info come from. i would like to buy the book.
Old Aug 14, 2003 | 05:15 PM
DeGideo's Avatar
DeGideo
Most of that information came from a 1994 F-Series brochure & a 1994 Bronco brochure. The cam specs were given to me by a Ford Tech at Ford Racing Performance Parts.
joesco
Jul 10, 2012 05:27 AM
nycbronco
Jun 25, 2011 02:57 PM
Honestbest333
New Member Introductions
Apr 17, 2009 03:50 PM
Nightrain
Jul 13, 2004 04:13 PM
mcrank
May 28, 2002 07:32 PM
