1978 - 1996 Big Bronco
'96 Bronco specs?
Old May 27, 2002 | 05:51 PM
mcrank's Avatar
mcrank
'96 Bronco specs?
Can anyone tell me the specs for a 96 full size bronco? it's for a standard 4x4. Engine size? Carb or Fi. axles? etc. Thanks again.
Old May 27, 2002 | 06:04 PM
DeGideo's Avatar
DeGideo
'96 Bronco specs?
Standard engine for the '96 Bronco was a 199(net) horsepower EFI5.0L(302cid)V-8.Optional was a EFI5.8L(351 cid) V-8 with 205(net) horsepower.The 351 was a $220 option over the base 302 engine.Standard transmission for XL&XLT Broncos was a 5-speed.A four-speed automatic was optional(standard with Eddie Bauer models&any Bronco ordered with the 5.8L engine.)The front axle is a Dana 44 TTB(Twin Traction Beam),and the rear axle was a 8.8" Ford.Axle gearing was either 3.55:1(open),or 3.55:1 with the optional rear-limited-slip.The code for a limited-slip 3.55:1 will be a H9 on the data decal located inside the driver's side door jam.The code for a non-limited-slip,or "open" 3.55:1 will be a 19.Engine codes are N(302)&H(351).
Old May 27, 2002 | 06:07 PM
mcrank's Avatar
mcrank
'96 Bronco specs?
Thanks for the super quick response. I appreciate the info and help:-)
Old May 28, 2002 | 07:32 PM
copester's Avatar
copester
'96 Bronco specs?
para
Apr 19, 2017 11:09 AM
crossy
Dec 2, 2016 09:10 PM
Fordman96
Ford Truck Parts for Sale
Mar 6, 2016 05:08 PM
JERSEY MUD
Offroad & 4x4
15
Nov 21, 2011 08:58 PM
marlies1h
New Member Introductions
Mar 8, 2006 07:12 AM
