steering
Old Aug 12, 2003 | 09:10 PM
shawn's Avatar
shawn
steering
i have a little give in my steering wheel is there any way to fix that..
Old Aug 13, 2003 | 01:34 AM
hermangarza's Avatar
hermangarza
steering
u mean its very loose
Old Aug 13, 2003 | 08:00 PM
85F_150driver's Avatar
85F_150driver
steering
The best way i know to check linkage parts for wear is to have someone turn the wheel slightly and watch to see if the pitman arm moves slightly before the rest of the parts.if you dont see any movement that is not normal then you probably have a warn out tie rod end. or worse a worn steering gear.
Old Aug 14, 2003 | 11:01 AM
Rick_Ford's Avatar
Rick_Ford
steering
I fixed mine by replacing the power steering gear.
Have someone turn the wheel back and forth while you watch all the steering linkages to see where the play is.
Rick
Old Aug 15, 2003 | 12:55 AM
fishmanndotcom's Avatar
fishmanndotcom
steering
Look on top of your steering box and there should be a nut threaded onto a bolt that goes into the box and there is a slit on top of the bolt. loosen the nut and then you can turn the 'bolt' ...i forget which way is tighten and which way is loosen....but give it a try!!
-Jason-
Old Aug 15, 2003 | 01:12 AM
85f-250-460's Avatar
85f-250-460
steering
also check the Kingpins. that was the last thing in my steering to replace and it made a noticable difference after the alignment
James
