Used PMC installed
Old Apr 13, 2016 | 07:50 PM
Russ5fish's Avatar
Russ5fish
I thought I was flashing it. Hooked up to a computer after purchasing a ford app but now I think it was just an upgrade. Going to set up an appointment with a ford dealer.
As far as the file on the old PCM it was the factory PCM.
Old Apr 14, 2016 | 10:51 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Originally Posted by Russ5fish
Well it appears I got the wrong PCM again! While flashing it, noticed it is a TBS5 instead of a TBS7. Oil pressure guage only working when rpm's are above 2000. No power and shifting as if its in tow haul. Learned a valuable lesson, YOU GET WHAT YOU PAY FOR!!
Originally Posted by Jeremy05
That should have worked. Tbs7 should just be a later family from tbs5. Still for a 2004 6.0 with a 2004 engine
What do you mean by "while flashing it"?
Also what can you tell us about the pcm you purchased? Do you know what the pcm file was on your old pcm?
Your low power and poor shifting reminds me of a plugged up ebp sensor.
What Jeremy said....
Also to Jeremy's point, the TBS5 PCM should have worked without issue.
Did you have the batteries disconnected before you plugged the PCM in?
These trucks are smarter than most people believe and can indeed learn some bad habits.
I suggest disconnecting the batteries for an hour, reconnecting them and seeing what the PCM does.
I too think you should make sure you EBP tube, fitting at the exhaust manifold, and sensor are clean and clear. If you still have and EGR, make sure that's clean as well.
Also, by PCM file, he meant what strategy was on the PCM. For example: VXBC3N2, VXBC6N4 etc
happscrap
Nov 24, 2014 07:43 PM
chetspencer
Nov 30, 2011 06:57 AM
akder
2004 - 2008 F150
May 2, 2011 12:39 AM
verticalrich
Aug 27, 2007 09:11 AM
