Starter bolts
Old Apr 1, 2016 | 05:09 PM
Peavey1986's Avatar
Peavey1986
Starter bolts
Ok so, I have a problem with my starter bolts coming lose and backing them selfs out. The other day this situation happened to me again. I went an got new bolts an this time I used lock washers . After installing the two bolts I started up the truck and it made a horrible sound coming from the separator plate . The noise sounded like metal rubbing. So I backed the bolts out a 1/4 of a turn an the sound went right away. Has anyone had this problem before with starter bolts backing them selfs out? The truck is a 86 f150 302efi . is there a fix? I did use blue lock tight also.
Old Apr 2, 2016 | 07:42 AM
Franklin2's Avatar
Franklin2
Sounds like the bolts you have are a little bit too long. Get a shorter bolt or cut a little bit off the ones you have and then tighten them down good. The lock washers and the locktite should cure the loosening problem.
Jointasset
28
May 24, 2017 09:49 AM
SC_Dave
13
Apr 26, 2013 06:39 PM
nickt916
21
Dec 21, 2012 10:54 AM
Ckc
Feb 10, 2012 07:55 PM
GHeTTo JOe
May 19, 2010 12:49 AM
