Help asap !!
Old Apr 1, 2016 | 08:53 AM
Tedster9's Avatar
Tedster9
The coil actually fires when the contact points open, the time they spend closed is called the "dwell", and the primary side of the coil is building up voltage.
The condenser (an old name for capacitor) is connected in parallel across the points, and prevents them from arcing and burning as the points open but it also makes the spark much stronger at the plugs, where it belongs.
Old Apr 1, 2016 | 09:26 AM
raytasch's Avatar
raytasch
Believe Nothing
Think of the condenser as arc suppression across the points.
Old Apr 1, 2016 | 12:20 PM
firstrider's Avatar
firstrider
Originally Posted by Tedster9
Yep, for some reason those capacitors are now difficult to manufacture in a small enough size and still meet the voltage requirement. Seems like somebody signs up here once a month or so with a brandy new genuine chinesium point and condenser set that's junk.
Tedster9 , you are a winner . Made an ugly 4 mi. trip over to my buddies at 9 a.m. this morning . Stalled , an fine for 1/2 mi. , stalled at an intersection but made it there .Started diagnosing the problem by process of elimination . Carb is new , checked fuel pressure = very good & good flow . He had some old school instruments . So instead of a $1.00 condenser I have a about a $500.00 condenser . Oh well at least I know all other components are new & in excellent working condition . .. Took it for a 7 mi. test drive at different rpm ranges .Let Pete drive it back .Think it was the high lite of the week for him . He really enjoyed it . He is building a '36
Thanks to all for your concern & help . Off to the shows sat. & sun.
When the + wire in the dist . shorted out it may have spiked the condenser .
Old Apr 1, 2016 | 12:40 PM
filthy6's Avatar
filthy6
This was fun to follow. You guys are the bomb.com I don't know of another place like this!
Old Apr 1, 2016 | 09:25 PM
Mervy49's Avatar
Mervy49
In the old days I always carried a little piece of fine sand paper to clean the points with. The points would would carbon up usually at a inconvenient time.
Old Apr 5, 2016 | 12:12 PM
petemcl's Avatar
petemcl
Denny,
I had a similar problem. I switched the points and condenser for a Pertronix Ignitor and a vented gas cap.
Old Apr 5, 2016 | 02:22 PM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
In a pinch, you could also use one of those emery boards women use to file their fingernails.
Old Apr 5, 2016 | 03:00 PM
Tedster9's Avatar
Tedster9
I heard a crisp new dollar bill works good too, if you can find one. $50 bill for you Alaskans and Californians.
Old Apr 5, 2016 | 04:34 PM
EffieTrucker
You can't file points in California without a carbon recovery system approved by Cal/EPA.
Old Apr 5, 2016 | 04:55 PM
pbsdaddy's Avatar
pbsdaddy
Back in "66", as a young working HS graduate, I bought a "35 coupe. Ran fine, with the exception of charging issues, for about 8 months. Then some times it would start, sometimes I needed a push to get it going. After much deliberation, frustration and mistakes, I learned the condenser had given up the ghost, thus causing my issues.
Great little pieces, as long as they work.
Old Apr 5, 2016 | 06:09 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
And the bill was signed by governor Moonbeam today to tax that carbon recovery action.
Old Apr 5, 2016 | 06:20 PM
toby tough's Avatar
toby tough
Will that bill help with our carbon footprints?
Old Apr 5, 2016 | 08:32 PM
  #28
firstrider's Avatar
firstrider
Tuesday night car show . No awards , just a 50/50 & door prizes . A good 250 cars , weather was perfect & the truck is running the best it ever has . Fri. night car show at the local church 4 mi. away & sat. at the Ace Hardware store in Stuart ( with awards ) 6.5 mi. away .
Old Apr 5, 2016 | 08:43 PM
  #29
3twinridges's Avatar
3twinridges
Denny you should pop the cap and show off your new condenser! Reading your thread makes me want to go change mine!
JB
Old Apr 6, 2016 | 12:32 AM
  #30
Mervy49's Avatar
Mervy49
Awesome pictures.
